Arcade Text Formatting - Bold Text
18095
17
01-30-2020 11:07 AM
ChantellKrider1
I'm having difficulty formatting the following expression such that result will BOLD words indicated below.
I understand that the labeling expression should be "<BOL>" + $feature.LABELFIELD + "</BOL>
/*Eligibility*/
if($feature["Comm_Eligi"]=="Eligible") {
if($feature["UP_Eligibl"]=="Eligible") {
return("Your jurisdiction is eligible under the Communities in Need criteria and the required minimum match is " + $feature["Comm_Match"] + " percent." + Textformatting.NewLine + "Your jurisdiction also is eligible under the Underserved Populations criteria: map your project to determine the required minimum match." )
} else {
return("Your jurisdiction is eligible under the Communities in Need criteria and the required minimum match is " + $feature["Comm_Match"] + " percent.")
} else if($feature["Comm_Eligi"]=="Not Eligible") {
if($feature["UP_Eligibl"]=="Not Eligible") {
return("Your jurisdiction is not eligible for a match reduction.")
} else {
return("Your jurisdiction is eligible under the Underserved Populations criteria: map your project to determine the required minimum match.")
Tags (1)
XanderBakker
Esri Esteemed Contributor
Hi chantell.krider_wa_rco
As I mentioned in my previous post, this does not work (yet) in ArcGIS Online. To create the bold text in the pop-up in ArcGIS Online will require custom HTML configuration and multiple Arcade expressions.
XanderBakker
Hi chantell.krider_wa_rco ,
I assume this would be like this:
/*Eligibility*/
if ($feature["Comm_Eligi"]=="Eligible") {
    if ($feature["UP_Eligibl"]=="Eligible") {
        return("Your jurisdiction is eligible under the <BOL>Communities in Need</BOL> criteria and the required minimum match is " + $feature["Comm_Match"] + " percent." + Textformatting.NewLine + "Your jurisdiction also is eligible under the <BOL>Underserved Populations</BOL> criteria: map your project to determine the required minimum match." )
    } else {
        return("Your jurisdiction is eligible under the <BOL>Communities in Need</BOL> criteria and the required minimum match is " + $feature["Comm_Match"] + " percent.")
} else if ($feature["Comm_Eligi"]=="Not Eligible") {
    if ($feature["UP_Eligibl"]=="Not Eligible") {
    } else {
        return("Your jurisdiction is eligible under the <BOL>Underserved Populations</BOL> criteria: map your project to determine the required minimum match.")
Note that this might work in ArcGIS Pro, but not (yet) in ArcGIS Online.
ChantellKrider1
Nope. The results are below.
XanderBakker
ChantellKrider1
Okay. Thank you for the help.
XanderBakker
Hi Chantell Krider ,
I can show you how to do this with the custom HTML configuration in combination with 4 Arcade expressions, if that's an option for you...
ChantellKrider1
Yes. That would be awesome!
XanderBakker
Let me first explain the sample dataset I created. I have 4 points and added the Com_Eligi and UP_Eligibl values:
The attribute table looks like this:
You can see that I have 4 "Eligibility" fields added, containing "block" or "none". Those are the results of the Arcade expressions listed below:
// Eligibility1:
if (($feature["Comm_Eligi"]=="Eligible") && ($feature["UP_Eligibl"]=="Eligible")) {
        return "block";
} else {
        return "none";
// Eligibility2:
if (($feature["Comm_Eligi"]=="Eligible") && ($feature["UP_Eligibl"]=="Not Eligible")) {
        return "block";
} else {
        return "none";
// Eligibility3:
if (($feature["Comm_Eligi"]=="Not Eligible") && ($feature["UP_Eligibl"]=="Not Eligible")) {
        return "block";
} else {
        return "none";
// Eligibility4:
if (($feature["Comm_Eligi"]=="Not Eligible") && ($feature["UP_Eligibl"]=="Eligible")) {
        return "block";
} else {
        return "none";
Those will appear numbered as 0 to 3 in the list of Arcade expressions in the pop-up configuration:
The next part is the configuration of the custom HTML pop-up:
Next hit the green "CONFIGURE" button and activate the "View HTML Source" in the Custom Attribute Display:
As HTML source you should copy and paste the following:
<span style="display:{expression/expr0}">Your jurisdiction is eligible under the <b>Communities in Need</b> criteria and the required minimum match is {Comm_Match} percent. <br />Your jurisdiction also is eligible under the <b>Underserved Populations</b> criteria: map your project to determine the required minimum match.</span>
<span style="display:{expression/expr1}">Your jurisdiction is eligible under the <b>Communities in Need</b> criteria and the required minimum match is {Comm_Match} percent.</span>
<span style="display:{expression/expr2}">Your jurisdiction is not eligible for a match reduction.</span>
<span style="display:{expression/expr3}">Your jurisdiction is eligible under the <b>Underserved Populations</b> criteria: map your project to determine the required minimum match.</span>
The result should be like this:
ChantellKrider1
Impressive! I'm guessing I'll need to pre-populate the attribute table according to the "blocks" vs. "none". Is that correct? Thank you! I'll give it a try.
XanderBakker
You do not have to change your data and add fields. The ones you are seeing are "virtual" fields created by the Arcade expressions.
