to bounding rectanlge in lot
259
01-29-2020 08:18 PM
chojeo
i  am seeking bounding rectangle function
i found simliar function
that is    "innerrect"
IInkAnalysisNode.RotatedBoundingRect Property (Windows.UI.Input.Inking.Analysis) - Windows UWP appli...
if you see link image ,  that is   roatated bounding rectangle
i am seeking that fucntion ?
how can i do ?
thank you always~
CherylLau
The scope will always be a bounding box around the geometry.  Currently, we do not have a way yet to align the scope in a way that minimizes the bounding box volume.  The best you could do is to align the scope to the longest edge in your geometry using alignScopeToGeometry() with edgeSelector=longest.  Then, once the scope is aligned, you could insert a primitiveCube() to get a box.
alignScopeToGeometry operation—CGA | Documentation
primitiveCube operation—CGA | Documentation
Note:  innerRect() is deprecated, and we recommend using innerRectangle() instead.
