ArcGIS Earth Basemap Problems
1165
5
01-28-2020 04:17 PM
JulieEckman1
New Contributor III
I want to use AG Earth (version 1.8) so I can provide a KMZ with a different basemap.  Unfortunately, the basemap will not resolve when zooming in closer than the whole earth.    When I open up the basemap icon, all of the basemap thumbnails are imbedded with an orange triangle containing an exclamation mark and I can't change the basemap.  I signed into both my portal and AGOL accounts with the same result, and the basemaps function normally in AGOL and ArcGIS Pro.  Has any one run across this problem?  Thank you...
JulieEckman1
New Contributor III
Good afternoon, Xuewen:
Thank you for the response.  I had our IT folks update my AG Earth to 1.9, and now it seems the basemaps work - they adjust resolution down to 1,000 foot eye level.  Consider this issue resolved.
Regards, Julie Eckman
RobertBorchert
Frequent Contributor III
Make me think it may be an issue with your internet connection and limitations.
JulieEckman1
New Contributor III
Robert, I was wondering that also, but am sort of perplexed with the basemaps functioning normally in AGOL usage (such as Map View and Dashboard) and in ArcGIS Pro.  Not sure if different portals are involved, but I will contact our IT folks.  Thank you.
RobertBorchert
I don't use Earth, but I started it up and added an air photo base map and everything worked just like it does in Google Earth.  Does it do it before you add your kmz?
XuewenZhang
Hi Julie,
Could you please help to check the spatial reference setting in ArcGIS Earth. In V1.8, there is a defect that if the tiled basemap spatial reference didn't match the spatial reference setting in Earth, then there is an orange triangle containing an exclamation mark.
You can check more detail from this question: Basemaps unavailable at 1.8
Xuewen
JulieEckman1
New Contributor III
