Edit Data in survey123 hyperlink from Collector
484
01-27-2020 09:17 AM
MattMulder
New Contributor III
survey123 is great for its cascading and pulling existing data from external data tables and I want to be able to use this delineation and data population ability to help with field workers. Currently the web version of a survey123 form allows editing capabilities of dataset with the URL schema:
 https://survey123.arcgis.com/share/XXXXXXXXXXXXXXXXX?mode=edit&objectId={OBJECTID}.
I've tried a similar URL setup in a collector pop-up, using the arcgis-survey123 setup which would push to the survey123 app but it won't push to the inbox in order to edit the specific data point. Is this a capability the app offers and I'm missing something or is it something not currently capable or will be?
DougBrowning
MVP Esteemed Contributor
