PopupTemplate with Custom Content. Finding xy of Selected Feature.
2453
9
01-23-2020 07:38 AM
BillMacPherson
New Contributor III
 This is a javascript api app with custom content for the popupTemplate. A custom function is used to build the content. When the function is called, by default, the selected feature is passed in. In this case, it is a polygon.
Finding normal map service attributes is no problem. For these I'm able to use both of the following calls.
feature.graphic.attributes.GL // works fine
feature.graphic.getAttribute("GL")); // works fine
Problem: I'm trying to get the x,y of the centroid of the selected feature, in map units. It seems that everything having to do with geometry of this feature is undefined.
Using ArcGIS javascript api 4.13
My app is based on this esri sample
Bill
Here's my code that doesn't return x,y
      let buildPopupContent; // fn used later to build popup content.
        let popupTemplate = {
          title: "Airport Tier: {Tier}",
          content:
            buildPopupContent
        // When the feature is clicked, this function is called. The feature is passed into the function.
        function buildPopupContent (feature) {
          let poly = feature.graphic.geometry;
            alert("x " + poly.centroid.x); // undefined
          var centerPoint = feature.graphic.geometry.getExtent().getCenter(); // Unable to get property 'getExtent' of undefined or null reference
          alert("x " + centerPoint.x);
popuptemplate‌, centroid‌, #custom issue
KenBuja
MVP Esteemed Contributor
When I substituted another feature layer, I get those properties of the feature. How is your service set up?
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8" />
  <meta name="viewport"
        content="initial-scale=1,maximum-scale=1,user-scalable=no" />
  <title>HAS javascript api 4.13</title>
  <link rel="stylesheet"
        href="https://js.arcgis.com/4.14/esri/themes/light/main.css" />
  <script src="https://js.arcgis.com/4.14/"></script>
  <style>
    html,
    body,
    #viewDiv {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    #optionsDiv {
      background-color: white;
      color: black;
      padding: 6px;
      max-width: 400px;
  </style>
  <script>
    //let buildPopupContent; // fn used later to build popup content.
    require([
      "esri/Map",
      "esri/Graphic",
      "esri/views/MapView",
      "esri/layers/FeatureLayer",
      "esri/PopupTemplate",
      "esri/geometry/Polygon",
      "esri/geometry/Point",
      "esri/geometry/Geometry"
    ], function (Map, Graphic, MapView, FeatureLayer) {
      let tier_FLayer = new FeatureLayer({
        url: "https://services.arcgis.com/P3ePLMYs2RVChkJx/ArcGIS/rest/services/ACS_Marital_Status_Boundaries/FeatureServer/2",
        outFields: ["*"]
      //let IAH_Elev_FLayer = new FeatureLayer({
      //  url: "http://10.88.22.95:6080/arcgis/rest/services/HAS/HAS_wm/MapServer/7",
      //  outFields: ["*"]
      //IAH_Elev_FLayer.visible = false;
      //let EFD_HOU_Elev_FLayer = new FeatureLayer({
      //  url: "http://10.88.22.95:6080/arcgis/rest/services/HAS/HAS_wm/MapServer/8",
      //  outFields: ["*"],
      //EFD_HOU_Elev_FLayer.visible = false;
      let map = new Map({
        basemap: "streets"
        , layers: [tier_FLayer]//, IAH_Elev_FLayer, EFD_HOU_Elev_FLayer]
      let view = new MapView({
        container: "viewDiv",
        map: map,
        center: [-95.4, 29.80],
        zoom: 11,
        popup: {
          //autoOpenEnabled: false,
          dockEnabled: true,
          dockOptions: {
            // dock popup at bottom-right side of view
            buttonEnabled: false,
            breakpoint: false,
            position: "top-right"
      //create graphic for mouse point click
      let pointGraphic = new Graphic({
        symbol: {
          type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
          color: [0, 0, 139],
          outline: {
            color: [255, 255, 255],
            width: 1.0
      tier_FLayer.load().then(function () {
        tier_FLayer.popupTemplate = popupTemplate;
      //IAH_Elev_FLayer.load().then(function () {
      //  IAH_Elev_FLayer.popupTemplate = popupTemplate;
      //EFD_HOU_Elev_FLayer.load().then(function () {
      //  EFD_HOU_Elev_FLayer.popupTemplate = popupTemplate;
        content:
          buildPopupContent
      // When the feature is clicked, this function is called. The feature is passed into the function. https://developers.arcgis.com/javascript/latest/sample-code/popuptemplate-function/index.html
      function buildPopupContent(feature) {
        console.log("feature type = " + feature.graphic.geometry.type); // ERROR: Unable to get property 'type' of undefined or null reference
        console.log("centroid x " + feature.graphic.geometry.centroid.x); // ERROR: Unable to get property 'centroid' of undefined or null reference
        console.log("extent center x = " + feature.graphic.geometry.extent.center.x); // ERROR: Unable to get property 'extent' of undefined or null reference
        //alert("ObjectId= " + feature.graphic.getAttribute("OBJECTID")); // works
        //alert("area= " + feature.graphic.getAttribute("Shape.area")); // works
        //alert("length= " + feature.graphic.getAttribute("Shape.len")); // works
        //alert("GL= " + feature.graphic.attributes.GL); // works
        //alert("GL= " + feature.graphic.getAttribute("GL")); // works
        let pointLatDMS = new DMS(feature.latitude); // feature converted to degree minute second.
        let pointLongDMS = new DMS(feature.longitude);
        let div = document.createElement("div");
        div.innerHTML = "<b>Check values and click submit to send to the FAA website.</b></br></br>" +
          "<form action='https://oeaaa.faa.gov/oeaaa/external/gisTools/gisAction.jsp?action=doNoNoticeRequiredTool' target='_blank' method='POST'>" +
          "<table border='0' cellpadding='0' cellspacing='0' width='800'>" +
          "<tr>" +
          "<td width='20%'> Latitude: </td>" +
          "<td  width='80%'><input type='text' name='latD' id='latD' size='3' maxlength='3' value=" + pointLatDMS.Degree + " tabindex=''> Deg  <input type='text' name='latM' id='latM' size='2' maxlength='2' value=" + pointLatDMS.Minute + " tabindex=''> M  <input type='text' name='latS' id='latS' size='5' maxlength='5' value=" + pointLatDMS.Second + " tabindex=''> S  <select name='latDir' id='latDir' tabindex=''><option value='N'>N</option><option value='S'>S</option></select> </td>" +
          "</tr>" +
          "<tr>" +
          "<td> Longitude: </td>" +
          "<td><input type='text' name='longD' id='longD' size='3' maxlength='3' value=" + pointLongDMS.Degree + " tabindex=''> Deg  <input type='text' name='longM' id='longM' size='2' maxlength='2' value=" + pointLongDMS.Minute + " tabindex=''> M  <input type='text' name='longS' id='longS' size='5' maxlength='5' value=" + pointLongDMS.Second + " tabindex=''> S  <select name='longDir' id='longDir' tabindex=''><option value='W'>W</option><option value='E'>E</option></select> </td>" +
          "</tr>" +
          "<TR>" +
          "<TD>Horizontal Datum:</TD>" +
          "<TD><select name='datum' id='datum' tabindex=''><option value='NAD83'>NAD83</option><option value='NAD27' selected >NAD27</option></select></TD>" +
          "</TR>" +
          "<TR>" +
          "<TD>Site Elevation (SE):</TD>" +
          "<TD><input type='text' name='siteElevation' id='siteElevation' size='5' maxlength='5' value=" + feature.graphic.attributes.GL + " tabindex=''> (nearest foot) </TD>" +
          "</TR>" +
          "<TR>" +
          "<TD>Structure Height (AGL):</TD>" +
          "<TD><input type='text' name='structureHeight' id='structureHeight' size='5' maxlength='5' value='222' tabindex=''> (nearest foot)</TD>" +
          "</TR>" +
          "<TR>" +
          "<TD>Airspace Elevation (AGL):</TD>" +
          "<TD><input type='text' name='airspaceElevationAGL' id='airspaceElevationAGL' size='5' maxlength='5' value='444'></TD>" +
          "</TR>" +
          "<TR>" +
          "<TD>Airspace Elevation (AMSL):</TD>" +
          "<TD><input type='text' name='airspaceElevationAMSL' id='airspaceElevationAMSL' size='5' maxlength='5' value='555'></TD>" +
          "</TR>" +
          "<TR>" +
          "<TD>Maximum Building Height:</TD>" +
          "<TD><input type='text' name='maxBldgHeight' id='maxBldgHeight' size='5' maxlength='5' value='350'></TD>" +
          "</TR>" +
          "<TR>" +
          "<TD>Airport Tier:</TD>" +
          "<TD><input type='text' name='airportTier' id='airportTier' size='20' maxlength='20' value=" + feature.graphic.attributes.Tier + "></TD>" +
          "</TR>" +
          "<TR>" +
          "<TD >Traverseway:</TD>" +
          "<TD ><select name='traverseway' id='traverseway' tabindex=''><option value='NO'>No Traverseway</option><option value='IH'>Interstate Highway</option><option value='OT'>Other Traverseway</option><option value='PR'>Private Road</option><option value='PH'>Public Roadway</option><option value='RR'>Railroad</option><option value='WW'>Waterway</option></select></TD>" +
          "</TR>" +
          "<TR>" +
          "<TD>Is structure on airport:</TD>" +
          "<TD><select name='onAirport' id='onAirport' tabindex=''><option value='false'>No</option><option value='true' selected >Yes</option></select></TD>" +
          "</TR>" +
          "<TR>" +
          "<td> </td>" +
          "<input type='submit' value='Submit to FAA Website'>" +
          "</TR>" +
          "</table> " +
          "</form>"
        return div;
      }; // end function buildPopupContent (feature)
      // Constructor function for DMS objects. https://www.w3schools.com/js/tryit.asp?filename=tryjs_object_constructor
      function DMS(coordInMeters) {
        this.Degree = "11";
        this.Minute = "22";
        this.Second = "33";
        // To do: convert to degree minute secons
        // How to Convert Decimal Degrees to DMS
        // 1.For the degrees use the whole number part of the decimal.
        // 2.For the minutes multiply the remaining decimal by 60. Use the whole number part of the answer as minutes.
        // 3.For the seconds multiply the new remaining decimal by 60
      // Workflow
      // User will click on the Airport Tiers polygon layer.
      // A point symbol is added to the map.
      // Depending on which Airport is clicked on (HOU,IAH,EFD),
      // the corresponding Airport Elevation layer will be queried.
      // Elevation info results will populate the popup.
      view.on("click", function (event) {
        view.graphics.remove(pointGraphic);
        //view.popup.remove();
        // query Tiers layer.
        queryFeatures_Tiers(event);
      function queryFeatures_Tiers(screenPoint) {
        // Converts the given screen point to a map point. This mapPoint is in the units of the map (meters).
        const mapPoint = view.toMap(screenPoint);
        tier_FLayer
          .queryFeatures({
            geometry: mapPoint,
            spatialRelationship: "intersects",
            returnGeometry: false,
            outFields: ["*"]
          .then(function (featureSet) {
            // Note: This function isn't executed when no Tier is returned.
            // set graphic location to mouse pointer and add to mapview
            pointGraphic.geometry = mapPoint;
            view.graphics.add(pointGraphic);
            //const graphics = results.features;
            let strTier = featureSet.features[0].attributes["Tier"];
            //alert(strTier);
            // Check user clicked on a Tier polygon
            // "Hobby", "Ellington", "GBIA"
            if (strTier.indexOf("GBIA") > -1) {
              queryFeatures_IAH(mapPoint);
            } else if (strTier.indexOf("Hobby") > -1) {
              queryFeatures_EFD_HOU(mapPoint);
            } else if (strTier.indexOf("Ellington") > -1) {
            } else {
              // This is never called.
              alert("Please click on one of the airports.")
      } // end queryFeatures_Tiers()
      function queryFeatures_IAH(mapPoint) {
        //const point = view.toMap(screenPoint);
        IAH_Elev_FLayer
          .queryFeatures({
            geometry: mapPoint,
            outFields: ["*"]
            // open popup of query result
            view.popup.open({
              features: featureSet.features,
              featureMenuOpen: true
      } // end queryFeatures_IAH()
      function queryFeatures_EFD_HOU(mapPoint) {
        EFD_HOU_Elev_FLayer
          .queryFeatures({
            geometry: mapPoint,
            outFields: ["*"]
            view.popup.open({
      } // end queryFeatures_EFD_HOU()
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
KenBuja
Why are you declaring buildPopupContent as a variable when you're using it as a function? (first line) Have you looked in the console to see what the variable feature in your function actually is?
If you substitute this code into the sample, it gives the x coordinates of the centroid and extent center as expected
function populationChange(feature) {
Note that you are using 3.x syntax instead of 4.x when you were declaring centerPoint
BillMacPherson
New Contributor III
Ken, Thank you very much for your quick help. I'm new to the javascript api (and javascript) so I thought there was some special reason for the function being declared as a variable. Thank you for clearing that up. It's gone now.
I added the lines you suggested and the objects came back undefined.
When I check the type, I it looks like the geometry object is undefined.
Since these same lines work in the ESRI sample app, I'm confused about the problem with the feature returned in my app.
I can get values for all of the feature attributes (including shape.area and shape.len) but nothing about the geometry.
The declaration of my FeatureLayer is simple.
          outFields: ["*"]
I don't see any properties to set about returning geometry or not.
Can you think of something else that I might try?
Bill
KenBuja
Can you post your entire code?
BillMacPherson
New Contributor III
Ken, Thanks for taking a look.
<!DOCTYPE html>
<html>
  <head>
    <meta
      name="viewport"
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.13/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.13/"></script>
    <style>
      html,
      body,
      #viewDiv {
        height100%;
        width100%;
        margin0;
        padding0;
      #optionsDiv {
        background-colorwhite;
        colorblack;
        padding6px;
        max-width400px;
    </style>
    <script>
      require([
        "esri/Map",
        "esri/Graphic",
      ], function(MapGraphicMapViewFeatureLayerPopupTemplatePolygonPointGeometrywebMercatorUtils) {
          url: "http://10.88.22.95:6080/arcgis/rest/services/HAS/HAS_wm/MapServer/9",
          outFields: ["*"]
          outFields: ["*"]
          outFields: ["*"],
        let map = new Map({
          basemap: "streets"
          ,layers: [tier_FLayerIAH_Elev_FLayerEFD_HOU_Elev_FLayer]
          map: map,
          center: [-95.429.80],
          zoom: 11,
          popup: {
            dockEnabled: true,
            dockOptions: {
              breakpoint: false,
          symbol: {
            type: "simple-marker"// autocasts as new SimpleMarkerSymbol()
            color: [00139],
            outline: {
              color: [255255255],
              width: 1.0
        tier_FLayer.load().then(function() {
        IAH_Elev_FLayer.load().then(function() {
        EFD_HOU_Elev_FLayer.load().then(function() {
          content:
            buildPopupContent
                "<tr>" +
                "</tr>" +
                "<tr>" +
                "</tr>" +
                "<TR>" +
                "</TR>" +
                "<TR>" +
                "</TR>" +
                "<TR>" +
                "</TR>" +
                "<TR>" +
                "</TR>" +
                "<TR>" +
                "</TR>" +
                "<TR>" +
                "</TR>" +
                "<TR>" +
                "</TR>" +
                "<TR>" +
                "</TR>" +
                "<TR>" +
                "</TR>" +
                "<TR>" +
                  "<td> </td>" +
                "</TR>" +
              "</table> " +
            "</form>"
          return div;
          this.Degree = "11";
          this.Minute = "22";
          this.Second = "33";
        // Workflow
        view.on("click"function(event) {
          tier_FLayer
            .queryFeatures({
              geometry: mapPoint,
              outFields: ["*"]
            .then(function(featureSet) {
              //alert(strTier);
              } else {
          IAH_Elev_FLayer
            .queryFeatures({
              geometry: mapPoint,
              outFields: ["*"]
              view.popup.open({
          EFD_HOU_Elev_FLayer
            .queryFeatures({
              geometry: mapPoint,
              outFields: ["*"]
              view.popup.open({
    </script>
  </head>
  <body>
  </body>
</html>
BillMacPherson
New Contributor III
Ken, Each of the featureLayers are polygons.
Bill
KenBuja
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    #optionsDiv {
      color: black;
      padding: 6px;
      max-width: 400px;
  </style>
  <script>
    require([
      "esri/Map",
      "esri/Graphic",
        outFields: ["*"]
      //  outFields: ["*"]
      let map = new Map({
        basemap: "streets"
        map: map,
        zoom: 11,
        popup: {
          dockEnabled: true,
          dockOptions: {
            breakpoint: false,
        symbol: {
          color: [0, 0, 139],
          outline: {
            width: 1.0
        content:
          buildPopupContent
          "<tr>" +
          "</tr>" +
          "<tr>" +
          "</tr>" +
          "<TR>" +
          "</TR>" +
          "<TR>" +
          "</TR>" +
          "<TR>" +
          "</TR>" +
          "<TR>" +
          "</TR>" +
          "<TR>" +
          "</TR>" +
          "<TR>" +
          "</TR>" +
          "<TR>" +
          "</TR>" +
          "<TR>" +
          "</TR>" +
          "<TR>" +
          "</TR>" +
          "<TR>" +
          "<td> </td>" +
          "</TR>" +
          "</table> " +
          "</form>"
        return div;
        this.Degree = "11";
        this.Minute = "22";
        this.Second = "33";
      // Workflow
        tier_FLayer
          .queryFeatures({
            geometry: mapPoint,
            outFields: ["*"]
            //alert(strTier);
            } else {
        IAH_Elev_FLayer
          .queryFeatures({
            geometry: mapPoint,
            outFields: ["*"]
            view.popup.open({
        EFD_HOU_Elev_FLayer
          .queryFeatures({
            geometry: mapPoint,
            outFields: ["*"]
            view.popup.open({
  </script>
</head>
<body>
</body>
</html>
BillMacPherson
New Contributor III
Ken, When you swapped out the layer and values returned, that surprised me. Then, when you asked about my map service setup, you got me looking harder at everything that I had glossed over before. My published map service looked alright. Nothing strange.
So, looking harder at my code, I found my dumb mistake. I had set up my query wrong. the 'returnGeometry' setting was set to false. I changed it to true and got good results from the lines you provided. Thank you very much for taking the time to get me over this hurdle. Now I can have a good weekend and I hope you have one too.
   from this...
          IAH_Elev_FLayer
            .queryFeatures({
              geometry: mapPoint,
              outFields: ["*"]
   to this...
          IAH_Elev_FLayer
            .queryFeatures({
              geometry: mapPoint,
              returnGeometry: true,
              outFields: ["*"]
Bill
RobertScheitlin__GISP
Make sure the shape and ObjectID fields are not hidden when the data was published.
BillMacPherson
New Contributor III
Robert, yes the ObjectID and shape fields are not hidden. I can retrieve values for them.
Ken, I will look more closely at how the service is set up. Hopefully something will look odd.
Thank you.
