Using " instead of inches in a field
1457
11
01-24-2020 11:05 AM
JimNoble
New Contributor III
Hi guys, I am trying to calculate a field to read 2" HDPE in every row
#Calculate field Conduit feature class Underground
arcpy.CalculateField_management("Underground.dbf", "Conduit",
                                '"2in HDPE"', "PYTHON3")
With this I can get every row to read 2in HDPE but everytime I try to insert " instead of in I get an error. Could you guys help me please!
Thanks!
-Jim Noble
GeoJosh
Jim,
Try this:
                                '"2\" HDPE"', "PYTHON3")‍‍
You need a forward back slash (\) before the parentheses ("). Otherwise, the Python interpreter will think you are trying to close the string.
Best,
Josh
JoshuaBixby
MVP Esteemed Contributor
Forward slash?  I think "\" is commonly called backslash.
Even with escaping the double quotes, the string still needs to be single quoted and not double quoted.
"'2\" HDPE'"
JimNoble
New Contributor III
Thanks Joshua, your fix worked perfectly.
JoeBorgione
Just got back from an ESRI user seminar: at pro 2.5 there finally is Find and Replace functionality!
Personally, I shy away from any special characters in database field values; notice how you need to escape them to get them in there. 'nuff said.....
DanPatterson_Retired
not quite the same... but "unicode" is quite a large world to fully explore.
dq = u"\u201D"
f"quoting{dq}"
'quoting”'
"quoting{}".format(dq)
'quoting”'
JoeBorgione
s = '12in pipe'
s = s.replace('in','\"')‍‍
print(s)
12" pipe
JimNoble
New Contributor III
Hi Joe, while your fix didn't pop any errors, it didn't actually fix the problem. Maybe I was using it wrong. This is what I put in.
#Set in name replace with quotation
s = '2in HDPE'
JoshuaBixby
Jim, using Joe's code didn't change anything because you ran it after Calculate Field.  The way the code is written now, you are using Calculate Field to update a table and then changing a string within Python but that change is never making it back into a data set.
JimNoble
New Contributor III
I see. Thanks for the explanation!
