ProjectWise
697
01-22-2020 10:43 AM
BeverlyRichey
Have placed a copy of a *.mxd with related *.GDB on Bentley's ProjectWise. Want to be able to "repair the broken links" with the *.GDB stored on ProjectWise verses our local copy (server, desktop, SDE, AGOL). Is this possible? Will research for this capability via the PW side also.
AdrianWelsh
MVP Honored Contributor
Hi Beverly,
I haven't used an MXD and file geodatabase in project wise. I found this article that might help. It looks like there is an extension you can use:
PWGSM3010 ProjectWise Geospatial iDesktop for ArcMap integration - Geospatial Services - Wiki - Geos...
If not then this article might help in linking the two together
Working with File Geodatabases
