Install Server and Portal Patches with PowerShell DSC
3786
12
01-21-2020 12:37 PM
KrystalPhaneuf2
I'm trying to figure out how to have patches installed when running the PowerShell DSC for an enterprise upgrade from 10.6.1 to 10.7.1.  In the github Wiki I see "PatchesDir" in the variables page but all it says is optional.  I'm wondering if this directory is where I need to download the patches to be installed or where the patches will be installed to.  Would this be the same as "InstallDir"?  What filepath are patches usually installed to?
Variables reference page for JSON configuration files · Esri/arcgis-powershell-dsc Wiki · GitHub
Cameron Kroeker are you able to assist?  Thanks!
CameronKroeker
Hi Krystal,
"PathesDir" is the path to where the patch (.msp) file(s) reside. The file path can be a local directory or a share, and can contain more than one .msp. PowerShell will detect all the .msp files in the path and proceed to install them.
Example:
"Portal": {
"LicenseFilePath": "[License File Path - Portal ]",
"PortalLicenseUserTypeId": "[Portal License User Type Id- Required for 10.7 and above]",
"Installer": {
"Path": "[Portal Installer Path]",
"WebStylesPath": "[Optional Parameter starting ArcGIS Enterprise 10.7.1 - Portal Web Styles Installer Path]",
"InstallDir": "[Portal Install Dir - Ex. C:\\ArcGIS\\Portal]",
"ContentDir": "[Portal Content Dir for Install- Ex. C:\\portalforarcgis\\content]",
"PatchesDir": "C:\\portal_patches"
Once installed you can find the patch(es) listed within Control Panel -> Programs -> Programs and Features -> Installed Updates.
list of installed patches within control panel
CameronKroeker
Hi Krystal,
Example:
"Portal": {
"Installer": {
KrystalPhaneuf2
Great thanks! I'll try this out tomorrow!
KrystalPhaneuf2
Just to confirm, there isn't anything else the config file needs to install the patches.  Just the "PatchesDir" variable under Portal and Server.
CameronKroeker
Yes, that's correct. As long as the "PatchesDir" attribute is present under Portal, Server, DataStore, etc and contains a local or file share path to a location where .msp files reside then the ArcGIS PowerShell module will install all the patches that are in the specified directory.
KrystalPhaneuf2
Hey Cameron,  I couldn't tell in your response but is the PatchesDir under Installer? This is how I've setup my config file.  This is based on the variables page in the github wiki.
"Portal": {
   "LicenseFilePath": "D:\\InstallationFiles\\1071\\ArcGIS_Enterprise_Portal_107_289384_20191127.json",
   "Installer": {
      "Path": "D:\\InstallationFiles\\1071\\Portal_for_ArcGIS_Windows_1071_169688.exe",
      "InstallDir": "C:\\Program Files\\ArcGIS\\Portal",
      "ContentDir": "D:\\",
      "PatchesDir": "D:\\InstallationFiles\\1071\\PortalPatches"
   "ContentDirectoryLocation": "D:\\arcgisportal\\content"
Github lists it like this:
Portal
  • Installer
    • Path - The path to the portal Installer file you downloaded from My Esri.
    • InstallDir - The path where the Portal component will be installed.
    • ContentDir - The Path where the initial site will be configured. This needs to be a Local Path.
    • WebStylesPath - The path to the Portal Web Styles Installer file you downloaded from My Esri. Required parameter starting 10.7.1.
    • PatchesDir - (Optional)
CameronKroeker
My apologies, yes, you are correct. PatchesDir goes under Installer.
Here is a sample:
arcgis-powershell-dsc/BaseDeployment   -SingleMachine.json at e06c6e3ba5f31707cce916a693c825bd616ec3...
KrystalPhaneuf2
Ok, that's how I set it up and they did not install.  Not even any errors or anything. Just didn't even attempt to install.  I'll open an issue on Github.
DanMcCoy
Occasional Contributor III
Cameron Kroeker
Does the "PatchesDir" attribute have to be under "DataStore" if you only have any patches to install for Server & Portal?
Dan
CameronKroeker
Hello Dan,
If there aren't any patches for ArcGIS DataStore then "PatchesDir" can be left out of "DataStore", even if there are patches to install for Server & Portal.
Cameron K.
