bgfield
When moving a feature, the feature snaps back to its original location if you subsequently edit an attribute
Discussion created by bgfield on Jan 21, 2020
Latest reply on Jan 21, 2020 by SHarris-esristaff
Scenario: I have a point.  I open up the edit toolbar, select the Move tool, and move the point.  I then edit a value of that same feature in the attribute table and press "enter" to save that edit.  The edit to the value I made saves, but the feature will move back to its original position before I moved it.  This is extremely problematic as if I'm not paying attention I might hit "save" thinking all the necessary edits have been made to a given feature layer when in fact the edits to the geometry I have made haven't actually been applied.
This is very bad for data integrity - I've already found instances where I have gone back and found some features where I know I had edited the geometry but the edits were not actually applied.  It's also completely counter-intuitive; if I move a feature I expect it to stay moved unless I discard/undo the edits, or forget to save (which is not the case here).
This needs to be fixed immediately - I shouldn't need to pay extra close attention to be sure my edits are being applied.
Outcomes
