24078 layers data source is not supported
1679
01-21-2020 03:25 AM
HusseinHammoud
Hello all,
I have made connection between ArcGIS Pro and an oracle database,
this oracle database was in another server,
I have a layer called Incidents, when I try to publish as web layer I got the following warning
"24078 layers data source is not supported."
any help please?
Asrujit_SenGupta
MVP Regular Contributor
HusseinHammoud
Thank you Asrujit SenGupta,
yes I have checked it, there is two suggestion,
1-Replace the unsupported data source with a supported database feature class.
2-Do nothing. The layer will be excluded from the web layer, web map, or web scene and the sharing process will continue.
I don't understand what should I do in first option, why my data source is not supported?
my table is a view in oracle has a column of type SDO_GEOMETRY(special column).
is this view not supported?
