Create polygon Feature version update
2057
01-19-2020 11:51 PM
Vakhtang_Zubiashvili
Hi all,
I am trying to create polygon feature, in JavaScript Version 4.9 it works, but when i change it in version 4.14 it does not work. I asked how to create polygon in another Question (Create Polygon Feature: Java Script  ), it seems everything OK, but sketch created sketch doesn't updates in featureLeyer (can not "Apply edits"). Here is a code from JavaScript version 4.9 that works fine, how can i update it in version 4.14?
Thanks.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Sketch View</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.14/esri/css/main.css">
  <script src="https://js.arcgis.com/4.9/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      font-family: verdana;
    #topbar {
      background: rgb(223, 34, 34);
      position: absolute;
      top: 15px;
      right: 15px;
      padding: 10px;
    .action-button {
      font-size: 16px;
      background-color: transparent;
      border: 1px solid #D3D3D3;
      color: #6e6e6e;
      height: 32px;
      width: 32px;
      text-align: center;
      box-shadow: 0 0 1px rgba(0, 0, 0, 0.3);
    .action-button:hover,
    .action-button:focus {
      background: #0079c1;
      color: #e4e4e4;
    .active {
      color: #e4e4e4;
    #info {
        padding: 14px;
        border-radius: 5px;
      #update {
        padding: 6px;
      #form {
        background: #fff;
      /* replaces esri-widget--panel */
      .scroller {
        overflow-x: hidden;
        overflow-y: auto;
  </style>
  <script>
    require([
      "esri/views/MapView",
      "esri/Map",
      "esri/widgets/Sketch/SketchViewModel",
      "esri/Graphic",
      "esri/layers/GraphicsLayer",
       "esri/layers/FeatureLayer",
      "esri/widgets/Expand",
      "esri/widgets/FeatureForm"
    ], function (
      MapView, Map,
      SketchViewModel, Graphic, GraphicsLayer, FeatureLayer, Expand, FeatureForm
      let highlight, editFeature;
       const featureLayer = new FeatureLayer({
        url: "http://localhost:6080/arcgis/rest/services/test/Request_Area/FeatureServer/0",
        outFields: ["*"],
        popupEnabled: false,
      // GraphicsLayer to hold graphics created via sketch view model
      const graphicsLayer = new GraphicsLayer({
      const map = new Map({
        basemap: "gray",
        layers: [graphicsLayer, featureLayer]
      const view = new MapView({
        container: "viewDiv",
        map: map,
        center: [44.7502, 41.725524],
          zoom: 12
      const pointSymbol = {
        type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
        style: "square",
        color: "#8A2BE2",
        outline: { // autocasts as new SimpleLineSymbol()
          color: [255, 255, 255],
          width: 3
      const polylineSymbol = {
        type: "simple-line", // autocasts as new SimpleLineSymbol()
        color: "#8A2BE2",
        width: "4",
        style: "dash"
      const polygonSymbol = {
        type: "simple-fill", // autocasts as new SimpleFillSymbol()
        color: "red",
        style: "solid",
        outline: {
          color: "red",
          width: 1
      var attributes;
      view.when(function () {
        // create a new sketch view model
        const sketchViewModel = new SketchViewModel({
          view,
          layer: graphicsLayer,
          pointSymbol,
          polylineSymbol,
          polygonSymbol
       setUpClickHandler();
      // Call FeatureLayer.applyEdits() with specified params.    ეს მონაკვეთი არ მუშაობს
      function applyEdits(params) {
        featureLayer.applyEdits(params).then(function(editsResult) {
          // Get the objectId of the newly added feature.
          // Call selectFeature function to highlight the new feature.
          if (editsResult.addFeatureResults.length > 0) {
            const objectId = editsResult.addFeatureResults[0].objectId;
            //selectFeature(objectId);
        .catch(function(error) {
          console.log("===============================================");
          console.error("[ applyEdits ] FAILURE: ", error.code, error.name,
            error.message);
          console.log("error = ", error);
        // Listen to create-complete event to add a newly created graphic to view
        sketchViewModel.on("create-complete", addGraphic);
        // Listen the sketchViewModel's update-complete and update-cancel events
        sketchViewModel.on("update-complete", updateGraphic);
        sketchViewModel.on("update-cancel", updateGraphic);
        // აქედან ვიწყებ ხვალ=====================================================
        // called when sketchViewModel's create-complete event is fired.
        function addGraphic(event) {
          // Create a new graphic and set its geometry to
          // `create-complete` event geometry.
          const graphic = new Graphic({
            geometry: event.geometry,
            symbol: sketchViewModel.graphic.symbol,
            attributes: attributes
          graphicsLayer.add(graphic);
               const edits = { //Fire the addFeatures function using the completed graphic
              addFeatures: [graphic]
              applyEdits(edits);
            console.log(graphic);
        // Runs when sketchViewModel's update-complete or update-cancel
        // events are fired.
        function updateGraphic(event) {
          // Create a new graphic and set its geometry event.geometry
          var graphic = new Graphic({
            symbol: editGraphic.symbol
          // set the editGraphic to null update is complete or cancelled.
          editGraphic = null;
        // set up logic to handle geometry update and reflect the update on "graphicsLayer"
        function setUpClickHandler() {
          view.on("click", function (event) {
            view.hitTest(event).then(function (response) {
              var results = response.results;
              if (results.length > 0) {
                for (var i = 0; i < results.length; i++) {
                  // Check if we're already editing a graphic
                  if (!editGraphic && results[i].graphic.layer.id === "tempGraphics") {
                    // Save a reference to the graphic we intend to update
                    editGraphic = results[i].graphic;
                    // Remove the graphic from the GraphicsLayer
                    // Sketch will handle displaying the graphic while being updated
                    graphicsLayer.remove(editGraphic);
                    sketchViewModel.update(editGraphic);
                    break;
        // activate the sketch to create a polygon
        var drawPolygonButton = document.getElementById("polygonButton");
        drawPolygonButton.onclick = function () {
          // set the sketch to create a polygon geometry
          sketchViewModel.create("polygon");
          setActiveButton(this);
  </script>
</head>
<body>
  <div id="viewDiv"></div>
    <div id="topbar">
      <button class="action-button esri-icon-polygon" id="polygonButton" type="button"
        title="Draw polygon"></button>
    </div>
    <div id="info" class="esri-widget">
      <h3>მონიშნეთ ობიექტი მონაცემების შესაცვლელად</h3>
    </div>
    <div id="update" class="esri-widget esri-hidden">
      <div id="form" class="scroller esri-component"></div>
      <input
        type="button"
        class="esri-button"
        value="მონაცემების ატვირთვა"
        id="btnUpdate"
      <br />
      <div id="deleteArea">
        <input
          type="button"
          class="esri-button"
          value="წაშალეთ ინციდენტი"
          id="btnDelete"
      </div>
    </div>
</body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
KenBuja
MVP Esteemed Contributor
Version 4.10 made breaking changes to the SketchViewModel, so you'll have to re-write your code: Changes for SketchViewModel at 4.10 | ArcGIS API for JavaScript 4.14
KenBuja
