Client filtered GeoEvent Server output
198
01-17-2020 01:57 PM
JeremyRoberts2
New Contributor III
Hello!
I was sent to this forum from the Qt runtime forum   So runtime does not have GeoEvent Server functionality baked into its API.  I was however able to manually open up a web socket, subscribe to a GeoEvent Server, and consume its output manually in our Qt/runtime based application.  My question is, when hitting that subscription URL is there a way to filter the output that gets streamed over the open web socket?  Just thinking that would be a more efficient way to minimized network traffic, especially for a mobile device, rather than streaming all the GeoEvent server's data and doing the filtering client side.
Thanks!
Jeremy
Stefan_Jung
Hi Jeremy Roberts‌,
you are absolutely right, that would be nice to do this on server side. As far as I know there is currently no way to do this to filter it on the server using Stream Layer or the out of the box websocket output. Sure you could create a few outputs and filter which data will be send via which output, but an output will always send all data it receives regardless of the client.
Best Stefan
