Popup title text Color ?
1542
01-16-2020 12:06 AM
MayurDodiya
I set up Web App Builder Developer Edition 2.14 created app using TabTheme, applied custom color (#88165b) for my application and deployed on IIS server.
I am trying to change text color of popup title to white but it doesn't change.
I tried inspect using developer tools, made changes to default.css, common.css, dojo-override.css ...
Where should I put below css to change the title color of Popup
.esriPopup .titlePane {
    color:white;
Mayur
Tags (1)
RobertScheitlin__GISP
Mayur,
   The fix for this is to remove all your css changes that you have attempted and comment out some lines in the LayoutManager.js file in the _getFixedThemeStyles function. Lines 4 - 8 below in the function I have commented out.
    _getFixedThemeStyles: function(theme){
      //fix popup
      var cssText = '.esriPopup .titlePane {background-color: ${mainBackgroundColor} !important;}';
      // if(theme.customStyles.mainBackgroundColor && utils.isLightColor(theme.customStyles.mainBackgroundColor)){
      //   var imageUrl = require.toUrl('jimu') + '/css/images/api_popup_light.png';
      //   cssText += '.esriPopup .titleButton {background: url(' + imageUrl + ') no-repeat}';
      //   cssText += '.esriPopup .titlePane {color: black}';
      if(theme.name === 'PlateauTheme'){
Mayur,
  In WAB popup the title does not appear in the titlebar it is the first thing in the popups content. In the image below "Traffic Camera:Sherman Minton Br." is the popups title.
MayurDodiya
Hi Robert,
Sorry for confusion, I mean Record Number, Previous - Next , Maximize and close button in Popup title bar.
I tried put css in /jimu.js/css but it doesn't change the color
popup.css
dojo-override.css
You have idea where should I change to make those title bar button color in white ?
Mayur
Mayur,
      //fix popup
MayurDodiya
Hi Robert,
That's perfect! Now I can see the buttons in white color.
Thank you so much.
Mayur
