I need to extract all Polygons from ShapeFile
610
01-15-2020 03:07 PM
CesarSaenz
Hi, I need to extract all Polygons from ShapeFile, i read the shapefile and load into map, but i cant extract polygons from them.
Any Idea in SDK NET the last version para WPF? Thank You  I noob in this api.
MichaelBranscomb
Esri Frequent Contributor
What would you like to do with the polygons?
Take a look at the following samples:
arcgis-runtime-samples-dotnet/FeatureCollectionLayerFromQuery.xaml.cs at master · Esri/arcgis-runtim...
arcgis-runtime-samples-dotnet/FeatureLayerQuery.xaml.cs at master · Esri/arcgis-runtime-samples-dotn...
The special whereclause to return all features is: "1=1".
Cheers
Mike
