Model Builder Help: error 001884
625
01-09-2020 05:38 PM
eliasrex1
I am creating a model that will do the following: segment a raw image, train a random trees classifier based on a feature class, and then classify that segmented image. The model works until the classify raster tool, that's when it fails. I think it has something to do with the locations of where I am saving the data. If I run the tool with default save locations and names, it works, if I change the names and locations of the segmented image or classifier definition file, then it fails.
I would appreciate any advice, thanks!
Tags (1)
eliasrex1
Sorry about that! I ended up realizing my mistake, I forgot to add ".ecd" to my classifier which was causing the error. Once I added that it worked.
DuncanHornby
MVP Notable Contributor
You have not shown us the problem you think it is, file paths; until you edit your question and include this information no one has any idea why this is failing.
eliasrex1
by Anonymous User
Not applicable
Thanks Elias - can you please mark your comment as the answer if it solved your post.
Cheers, Chris
