Survey123 Inbox - Query to filter based on user inputs
2130
7
01-09-2020 09:31 PM
JamesBailey
If a user selects a city from a drop down in my survey e.g. New York, Washington, Chicago etc. can the inbox be searched by the "city" field without the full name being entered (New returns New York, York also returns New York).
If so, how would the query be written?
Thanks in advance
JamesTedrick
Esri Esteemed Contributor
Hi James,
The Inbox uses the text specified by the instance_name to label and search records.  If the field with city names is in the instance_name, you should be able to search as you describe.
JamesBailey
The instance name is just the city name but I am finding that when imputing letters into the Inbox Search Bar i.e. "L", I am getting results of locations that does not contain the letter L.
Why would this happen?
Cheers
JamesTedrick
My apologies,
The Inbox actually searches through all fields. We made a change in 3.7 to not search metadata fields (globalID, objectID, etc)- I got the scope of this change temporarily confused when I was writing my response.
JamesBailey
Is it possible to have inbox search function only search instance name or a specific field within the survey?
JamesTedrick
Hi James,
There currently is an option to limit the filtering to instance_name or specific fields.  Could I ask that you create an entry at https://ideas.arcgis.com so that we can understand what options would be preferred if that would be implemented?
JamesBailey
Idea entry created (https://community.esri.com/ideas/17884 ).
Cheers
JamesBailey
How is this done? I couldn't find any mention of how to limit the inbox search function to only search instance_name or other specific field.
Cheers
