ArcCatalog crashes working with a view
496
01-07-2020 04:18 PM
MarkMindlin
Occasional Contributor III
We have a problem working with a view.
The view is created in ArcCatalog
- right click on a database connection
- create a View
- use SQL "select x0.objectid as f1, x0.any_field as f2 from TABLE_NAME x0"
Both fields are Long Integer.
Looking to the properties of the view crashes ArcCatalog without any error message.
ArcGIS 10.6.1
Informix 12.1
KoryKramer
Esri Community Moderator
I see that you have already opened a case with technical support.  That is good as it is unlikely much progress would be made on this in a GeoNet forum.
