Problem with gradient stroke when printing/exporting
677
01-05-2020 06:30 PM
EricCompas
New Contributor III
I'm experimenting with gradient strokes for area boundaries following John Nelson's guide (Boundary Dropshadow Mega-Hack ) and while everything looks great in ArcGIS Pro, the output (this is for a print publication) is unusable.
Here's what the boundary looks like in ArcGIS Pro:
border in ArcGIS Pro
Here's what the boundary looks like in a PDF file (viewed at 400%):
border in PDF
I get the same PDF output using default (mix vector/raster) and "Output As Image" (raster only) options for the PDF export. Same for PNG exports. Anyone have suggestions for fixing this for a professional output format?
Eric
ShaneMiles
Hi Eric Compas‌,
Did you ever figure out what was happening with this? I've been playing around with it and haven't experienced any export issues as of yet.
Drop shadow
Potentially look at the Output Image quality ratio in Configuring map export as well as the troubleshooting for some assistance.
Shane
EricCompas1
Shane,
Thanks for responding. No, I haven't found a workaround yet. I'm using the "Best" setting in the Image Quality export layout options (note that the link you provide is to ArcMap and not ArcGIS Pro; here's the correct link).
I notice that your gradient is outside your boundary, so I gave that a try. Same result (gradient overlap on west boundary of park):
I'm using Pro 2.4.3. Do you have a newer, internal version where this issue's been fixed?
Eric
