Generate Geodatabase
1156
12
01-06-2020 06:18 AM
jaykapalczynski
I am using the template example in appstudio to test downloading a geodatabase.  Its working as it seems it should but I have a question that maybe someone can help answer
In the example it is setting up some Geodatabase Parameters.  One of these is the Bounding box that the user specifies and as such all features within this box are downloaded to the Geodatabase.
My question.  Can I add w where clause anywhere in there?
// create the generate geodatabase parameters
GenerateGeodatabaseParameters {
    extent: generateExtent
    outSpatialReference: SpatialReference.createWebMercator()
    returnAttachments: false
I tried this but getting errors...
QueryParameters {
    whereClause: "created_user = 'Law'"
    QueryParameters: params
ErwinSoekianto
Based on this documentation, GenerateGeodatabaseParameters QML Type | ArcGIS for Developers , GenerateGeodatabaseParameters does not have QueryParameters as listed property.
I am including ArcGIS Runtime SDK for Qt‌, to see if there is another way to achieve what you are asking.
jaykapalczynski
Thanks for your thoughts...
I can set up a definition expression after the fact but would like to include the limitation of records before the download occurs.  That make sense?  As the dataset gets larger I want to be able to limit the records downloaded by date range and user.  Then do the download.....
LucasDanzinger
Esri Frequent Contributor
You can specify GenerateLayerOptions in the GenerateGeodatabaseParameters. This allows you to specify a where clause for each layer - GenerateGeodatabaseParameters QML Type | ArcGIS for Developers
jaykapalczynski
OK I see in the example here that they are referencing the layerOptions....was was leaning towards this potentially being a solution....
Although not sure how to proceed....would this be the area that I implement that....and what would be the syntax
if I work it in below is this done before the download occurs?
how would I add a date range and created_user = 'user1'
would it be something like this?  layerOption2   ????
Again I am using the base template in appstudio for GenerateGeodatabase
                onLoadStatusChanged: {
                    if (loadStatus === Enums.LoadStatusLoaded) {
                        var idInfos = featureServiceInfo.layerInfos;
                        for (var i = 0; i < idInfos.length; i++) {
                            // add the layer to the map
                            var featureLayerUrl = featureServiceInfo.url + "/" + idInfos[i].infoId;
                            var serviceFeatureTable = ArcGISRuntimeEnvironment.createObject("ServiceFeatureTable", {url: featureLayerUrl});
                            var featureLayer = ArcGISRuntimeEnvironment.createObject("FeatureLayer", {featureTable: serviceFeatureTable});
                            map.operationalLayers.append(featureLayer);
                            // add a new GenerateLayerOption to array for use in the GenerateGeodatabaseParameters
                            var layerOption = ArcGISRuntimeEnvironment.createObject("GenerateLayerOption", {layerId: idInfos[i].infoId});
                            var layerOption2 = ArcGISRuntimeEnvironment.createObject("GenerateLayerOption", {whereClause: "created_user = 'law' "});
                            generateLayerOptions.push(layerOption);
                            generateLayerOptions.push(layerOption2);
                            generateParameters.layerOptions = generateLayerOptions;
jaykapalczynski
I think i got it with this
testing now...
          {layerId: idInfos[i].infoId, whereClause: "created_user = 'law' "});
                            var layerOption  = ArcGISRuntimeEnvironment.createObject("GenerateLayerOption", {layerId: idInfos[i].infoId, whereClause: "created_user = 'law' "});
jaykapalczynski
Maybe someone can help with the where clause...
This seems to work
var userWhereClause = "created_user = 'Esri_Anonymous' ";
BUT I cannot get the date ranges queries to work....thoughts on syntax?
//DATE VARIABLES
var startdate = "2020-1-03";
var enddate = "2020-1-20";
// WHERE CLAUSE
//var userWhereClause = "created_date BETWEEN DATE '" + startdate + "' AND DATE '" + enddate + "'  ";
// var userWhereClause = "created_date >= DATE ' " + startdate + " ' ";
ErwinSoekianto
Refer to this blog for Date-Time query, Querying Feature Services: Date-Time Queries
jaykapalczynski
Yea I have been referencing that blog from another post...still something weird going on...
I am successful in creating a definitionExpression on a Feature layer as such:
ALL THREE examples below including the DATE greater than and between work just fine...
//DATE VARIABLES
var exactdate = "2020-01-04";
var startdate = "2019-12-01";
var enddate = "2019-12-30";
// USER NAME
//featurelayer.definitionExpression = "created_user = 'Esri_Anonymous'";
// AFTER DATE
//featurelayer.definitionExpression = "created_date >= DATE'" + startdate + "'";
// BETWEEN DATES
//featurelayer.definitionExpression = "created_date BETWEEN DATE'" + startdate + "' AND DATE '" + enddate + "' ";
I try and use this same logic and syntax to create a GenerateLayerOption and I get varied results
This example works just fine....it grabs only the rescords with the created_user = Esri_Anonymous
BUT when I try and use the DATEs it blows up and dosent work properly...
IT works in the DefinitionExpression but the same syntax on the same dataset does not work?????
var userWhereClause = "created_date BETWEEN DATE'" + startdate + "' AND DATE '" + enddate + "' ";
       // QUERY DATES
       //DATE VARIABLES
       // WHERE CLAUSE
       //var userWhereClause = "created_user = 'Esri_Anonymous' ";
       //var userWhereClause = "created_date BETWEEN DATE'" + startdate + "' AND DATE '" + enddate + "' ";
       var layerOption  = ArcGISRuntimeEnvironment.createObject("GenerateLayerOption", {layerId: idInfos[i].infoId, whereClause: userWhereClause});
by Anonymous User
Not applicable
Hi Jay
Try adding in brackets around the actual date. e.g.
var myDate = new Date();
//make these some other dates obviously...
var startDate = new Date();
var finishDate = new Date();
var dateQueryString = "(date(%1) BETWEEN date('%2') AND date('%3'))".arg(myDate.toISOString()).arg(startDate.toISOString()).arg(finishDate.toISOString());
