Pro Add Package Install Location
272
12-30-2019 07:39 AM
MichaelVolz
Esteemed Contributor
In order to install and access additional useful python modules in Pro, you are required to clone the environment.  If you use the default location for the clone all the required files are copied to that location which is:
C:\Users\"User Name"\AppData\Local\ESRI\conda
Now if you choose a different (say simpler path) of C:\Python_Clone_Pro, many files do go to this location, but other files such as added modules go to a default location that it not appear that you can change:
C:\Users\"User Name"\AppData\Local\ESRI\conda.
Are there any negative impacts to having this broken up environment where python files exist in 2 locations, instead of going with the default install location for the clones?
