Cannot log in with different ArcGIS Portal user account using ArcGIS Python API
1487
12-31-2019 03:12 AM
ChrisBuckmaster2
New Contributor III
I have an ArcGIS Portal log in account (viewer account) in an enterprise GIS infrastructure and want to use the ArcGIS Python API to connect with a separate admin account to be able to produce reports on the ArcGIS Portal instance (layers being used in web maps, user last login stats etc).
When trying to connect using an admin account, it automatically connects with my viewer account (I am assuming my account is somehow automatically authorised within my network).
How am I able to explicitly log in with a different account using the ArcGIS Python API?
My script to connect is below:
from arcgis.gis import GIS
import getpass
password = getpass.getpass("Enter password: ")
gis = GIS("https://server/portal/home""admin_account", password)
print("Connected as: " + gis.properties.user.username + " on " + gis.properties.customBaseUrl)
print(gis.properties.user)
GeoJosh
Hey Chris,
Does your Portal use Integrated Windows Authentication? If so, try replacing the URL with the fully qualified domain name and port number. (https://portalMachine.domain:7443/arcgis/home) You should not be automatically authenticated as the viewer account when using this URL.
-Josh
GeoJosh
Hey Chris,
-Josh
ChrisBuckmaster2
New Contributor III
Hi Joshua
Brilliant that worked!
I was using the URL path https://civvmi-esriapp1.unifiedgov.co.uk/portal/home/ but I changed it to https://civvmi-esriapp1.unifiedgov.co.uk:7443/arcgis/home/.
Clearly using 'portal' instead of 'arcgis' was an issue.
Thanks again
