mkoneya
Add Layer to Map on Disk
Discussion created by mkoneya on Mar 20, 2011
Latest reply on Mar 21, 2011 by mkoneya
How do I add a Layer to a Map that is not the "CURRENT" map?
If I run the code below, the layer is added to the map that is open
lyrFile = "F:\COS_agsdata\PrintLayerFiles\Parcels.lyr"
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
lyr = arcpy.mapping.Layer(lyrFile)
arcpy.mapping.AddLayer(df, lyr)
If I run this code
mapDoc = "F:\COS_agsdata\PrintedMapDocuments\PythonTest.mxd"
mxd = arcpy.mapping.MapDocument(mapDoc)
The map on disk is not updated.
I tried an mxd.save, but that didn't work.     Do I need to update the document with the newly added layer?
Any assistance would be appreciated.
Mele
Outcomes
