Display mmpk Issues
482
12-18-2019 08:26 AM
jaykapalczynski
I created a mmpk as follows...this has been all through testing...
1. created a TPK with aerials
2. I then took the tpk and added contour lines and created the mmpk...
When I use the Quick Report template and point the offline button to this mmpk it draw the aerials and contour lines fine...everything looks great.
But I have a separate page that I am trying to show this mmpk file on and ONLY the aerials show up...the contours are not showing....I imagine only the first index in the mmpk is drawing?  NO idea here.
I am trying to show this .mmpk in a few different ways but neither shows the contour lines....is there something that I am missing.  In the Quick report template there is code for a   MobileMapPackage {  but not in my second page.  NOTE that I have a few mmpk files and 2 tpk files that I want the user to be able to display.  Right now just trying to get the mmpk file to draw correctly with the contours.
ListModel {
        ListElement { text: "Second TPK Basemap"; map: "file:///storage/82FF-66AD/Android/data/QuickReport/backgrounddatammpk.mmpk" }
        ListElement { text: "Second TPK Basemap"; map: "file:///storage/82FF-66AD/Android/data/QuickReport/District_23.mmpk" }
        ListElement { text: "Second TPK Basemap"; map: "file:///storage/82FF-66AD/Android/data/QuickReport/sd.tpk" }
        ListElement { text: "Second TPK Basemap"; map: "file:///storage/82FF-66AD/Android/data/QuickReport/District41_100Ft_Contours.mmpk" }
Basemap {
// OR
Basemap {
   ArcGISTiledLayer {
      url: tpkList.get(3).map
// OR
Basemap {
   MobileMapPackage {
      path: tpkList.get(3).map
ErwinSoekianto
Jay,
That is weird because it is showing correctly on another page in the same app. Perhaps you can look at the code on that other page that is working?
Or they are different workflows on loading the MMPK files. does the offline button in QuickReport point to ArcGIS Online item that has the MMPK file instead of pointing to MMPK files on disk?
Thank you,
Erwin
jaykapalczynski
Yea this one is puzzlin me...
As you can see from the two wexamples below I am pointing to the same mmpk file on the storage card.
file:///storage/82FF-66AD/Android/data/com.xxxx.background.data/QuickReport/backgrounddatammpk.mmpk
On the RefineLocationPage.qml page from the Quick report Template I am pushing the path to my Storage Card
RefineLocationPage.qml file
        MobileMapPackage {
            path: app.mmpkManager.fileUrl1
            onLoadStatusChanged: {
                if (loadStatus === Enums.LoadStatusLoaded) {
                    mapView.map = mmpk.maps[0];
                    isOfflineMap = true;
                    if(refineLocationPage.currentExt){
                        mapView.setViewpointGeometry(refineLocationPage.currentExt);
MmpkManger.qml file to GET the propoer path/url to the file
    property string subFolder: "QuickReport"
    property string itemName1: "backgrounddatammpk.mmpk"
    property url fileUrl1: [fileFolder1.url, itemName1].join("/")
    FileFolder{
        readonly property url storageBasePath: "file://" + "/storage/82FF-66AD/Android/data/" + "com.xxxx.background.data"
        property url storagePath: subFolder && subFolder>"" ? storageBasePath + "/" + subFolder : storageBasePath
        url: storagePath
On my second page I am simply displaying the mmpk file as an ArcGISTiledLayer as such
The reason I have it set up this way is that I have a button that allows the user to click through a few basemaps.
    ListModel {
        ListElement { text: "Second TPK Basemap"; map: "file:///storage/82FF-66AD/Android/data/com.xxxx.background.data/QuickReport/backgrounddatammpk.mmpk" }
        ListElement { text: "Second TPK Basemap"; map: "file:///storage/82FF-66AD/Android/data/com.xxxx.background.data/QuickReport/District_23.mmpk" }
        ListElement { text: "Second TPK Basemap"; map: "file:///storage/82FF-66AD/Android/data/com.xxxx.background.data/QuickReport/Richmond.tpk" }
        ListElement { text: "Second TPK Basemap"; map: "file:///storage/82FF-66AD/Android/data/com.xxxx.background.data/QuickReport/District41_100Ft_Contours.mmpk" }
Basemap {
Component.onCompleted: {
    var tpkPath = tpkList.get(0).map
    var tpkBasemap = ArcGISRuntimeEnvironment.createObject("ArcGISTiledLayer", {url: tpkPath});
    basemap.baseLayers.clear();
    basemap.baseLayers.append(tpkBasemap);
