ArcSOC optimizer in Edit mode
941
5
12-16-2019 09:57 PM
VictorTey
When I change the task to "edit" mode, I get the following error:
Traceback (most recent call last): File "ArcSOCOptimizer.py", line 11, in main File "Modules\Outputs\ReportBuilder.py", line 15, in __init__ File "Modules\Outputs\OutputBuilder.py", line 20, in __init__ File "Modules\ServiceStats\AGSAdmin.py", line 18, in __init__ TypeError: argument of type 'NoneType' is not iterable Traceback (most recent call last): File "ArcSOCOptimizer.py", line 11, in main File "Modules\Outputs\ReportBuilder.py", line 15, in __init__ File "Modules\Outputs\OutputBuilder.py", line 20, in __init__ File "Modules\ServiceStats\AGSAdmin.py", line 18, in __init__ TypeError: argument of type 'NoneType' is not iterable
I have checked the following
  • SiteUrl and tokenUrl matches ArcGIS Counter and optimizer
  • ArcGIS Monitor credential i use the default user: Site (tested the login and it works)
  • Also confirm credentials are the same for the counter and optimizer.
  • Tested without adaptor but still fail
running test.bat
list mode works fine
Edit mode I get:
Error while fetching tokens from admin URL. Please check the URL and try again.
Environmenet is enterprise 10.5.1
ArcGIS Monitor : 10.6.1
Thank you in advance
by Anonymous User
Not applicable
The recommended solution is to remove the special characters from the PSA account which is being used in the "Select a Credential field".
VictorTey
Just a update,
Running the optimizer bypassing the webadaptor yield
Traceback (most recent call last): File "ArcSOCOptimizer.py", line 11, in main File "Modules\Outputs\ReportBuilder.py", line 15, in __init__ File "Modules\Outputs\OutputBuilder.py", line 20, in __init__ File "Modules\ServiceStats\AGSAdmin.py", line 29, in __init__ ValueError: token error Traceback (most recent call last): File "ArcSOCOptimizer.py", line 11, in main File "Modules\Outputs\ReportBuilder.py", line 15, in __init__ File "Modules\Outputs\OutputBuilder.py", line 20, in __init__ File "Modules\ServiceStats\AGSAdmin.py", line 29, in __init__ ValueError: token error
However running it with Test.bat returned something more promising. I only just setup the counter bypassing the webadaptor. i will wait a day and test again. However it is as simple as that.
__GetPercentCommittedBytesInUseMax 78
__GetLogicalCoresMin 4
list index out of range
File "Modules\Outputs\ReportBuilder.py", line 22, in __init__
File "Modules\Outputs\ReportBuilder.py", line 69, in __Write
IndexError: list index out of range
None
by Anonymous User
Not applicable
Let's focus on the Token Error.  I have seen issues like this when special characters are used in the Primary Site Administrator (PSA)  password. which is used "Select a Credential" field.  Change your password for the PSA account; test it without using any special characters (just letters and numbers).
VictorTey
Thank you Michael for your feedback. I will give that a try.
VictorTey
Hi Michael Reither‌, I have tested it with a domain account with a password that doesn't contain special character, only letters(caps and non caps) + numbers.
Still getting the same error. However, running the optimizer.exe with the test.bat works great
by Anonymous User
Not applicable
