AnsweredAssumed Answered
CCTV Manager Errors
Question asked by mkurkowski_fveng on Dec 15, 2019
Latest reply on Dec 20, 2019 by mkurkowski_fveng
I'm trying to run the CCTV manager with the sample data and the GenerateCCTVPipeFeatures isn't working. Here are the errors I am seeing in Python.
File "<string>", line 94, in <module>
File "C:\Users\mattk\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\utilsolutions\esri\arcpy\UtilitySolutions.py", line 244, in GenerateCCTVPipeFeatures
shape_length, cctv_id, video_path, media_folder])
File "C:\Users\mattk\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\utilsolutions\esri\arcpy\UtilitySolutions.py", line 17, in _runner
raise e
File "C:\Users\mattk\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\utilsolutions\esri\arcpy\UtilitySolutions.py", line 15, in _runner
return convertArcObjectToPythonObject(func(*gp_fixargs(args, True)))
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000800: The value is not a member of PACP v6.0.4 | PACP v7.0.7 | ITpipes v1.5.43 | Custom.
ERROR 000732: Media Inspections Table: Dataset MEDIA_INSPECTIONS does not exist or is not supported
ERROR 000732: Media Conditions Table: Dataset MEDIA_CONDITIONS does not exist or is not supported
ERROR 000308: Invalid field type
Failed to execute (GenerateCCTVPipeFeatures).
Outcomes
