Feedback Experience Builder
519
12-12-2019 06:23 AM
MatthiasDufour
New Contributor III
Hi
Here is feedback from my use of Experience Builder :
In final version, Will Experience Builder exist in several languages?
My problem is not with the backend but with the frontend.
Some interfaces or messages are in English :
  • "Search" in List widget
  • "Waiting for data source" during a data load
  • "No Data"
  • Feature Info Widget (0 of 00)
  • Share widget (non-customizable email text)
  • Some tooltips (measure)
For improve the users experience of the website, I would like to know if it will be possible to modify these expressions.
In a Map widget, it would be nice to be able to customize the thumbnails (bottom left) that go from one view to another. thumbnail of a feature set is not always relevant in this case.
In the Share Widget, Could you add the ability to change the order of icons ?
In the Widget Feature Info, Could you add the possibility of sorting the records with a field (as with the Widget List) ?
In the Feature Info Widget, to improve navigation, is it possible to add controls to go directly to the start and end of the list (<< < 0 of 00 > >>) ?
In List widget, would it be possible to add a grid layout, like "Minimal Gallery" apps (https://www.arcgis.com/apps/MinimalGallery/index.html) ?
In the SQL Expression Builder, for a date field, is it possible to add the operators "greater than" and "less than"? for filtering over a period.
In the Expression Builder edit box, we can not paste text. This could simplify the creation of expression.
Matthias
Tags (1)
