generate road network model using ce sdk
439
12-09-2019 08:03 PM
夕林
hi everyone, I want to use ce sdk to generate road network model from osm map. I downloaded the sdk example prt4cmd and successfully got a nice looking building model. But it seems that the initial shape of the ce sdk has to befaces. Is CE sdk not supporting the generation of road network for now? If it supports, can you please kindly give me an example of using ce sdk to generate road network?
looking forward to your anwsers.
Thank you very much.
SimonHaegler
Apologies for the late answer.
CityEngine SDK can indeed only operate on faces. A workaround is to export the street shapes generated by CityEngine as OBJ (or Collada or FBX) and then use these files as input to your CE SDK based app.
I hope this works for you & kind regards,
Simon
