Update raster width/height with pro sdk
1360
8
12-08-2019 05:08 PM
by Anonymous User
Not applicable
Hi Gurus,
Refer to this
Create RasterDataset
After managed to create raster dataset, tried and change the raster size and update the extent and it does not update my raster properties.
SetExtent, SetWidth, SetHeight methods are used.
May I know what went wrong?
Below is my code snippet.
  string ExportTifFile = FileName + ".tif";
                    var parameters = Geoprocessing.MakeValueArray(
                         this.InputModel.DestinationPath, // Output path
                        ExportTifFile, // Raster name : make it as tif file
                         rasterInfo.CellSize.ToString(), // Cellsize
                         this.InputModel.PixelType, // pixel type
                         this._lastSelectedSR, // Spatial reference,
                         1); // Bands count
                    //IReadOnlyList<KeyValuePair<string, string>> environments = Geoprocessing.MakeEnvironmentArray(extent: pEnvelope);
                    var gpResult = Geoprocessing.ExecuteToolAsync("CreateRasterDataset_management", parameters, null,
                                        CancelableProgressor.None, GPExecuteToolFlags.GPThread);
                    gpResult.Wait();
                    IGPResult ProcessingResult =  gpResult.Result;
                    if (ProcessingResult.IsFailed)
                       foreach(IGPMessage message in ProcessingResult.Messages)
                            ConversionToolModule.Current.ModuleLogManager.LogError("Error on create raster dataset tool calling");
                            ConversionToolModule.Current.ModuleLogManager.LogError($"{{Error Code: {message.ErrorCode}, Text :  {message.Text} }}");
                        Geoprocessing.ShowMessageBox(ProcessingResult.Messages, "Raster creation error", GPMessageBoxStyle.Error);
//Try and update
await QueuedTask.Run(() =>
                        FileSystemConnectionPath connectionPath = new FileSystemConnectionPath(new System.Uri(this.InputModel.DestinationPath), FileSystemDatastoreType.Raster);
                        FileSystemDatastore datastore = new FileSystemDatastore(connectionPath);
                        RasterDataset tmpFileRasterDataset = datastore.OpenDataset<RasterDataset>(ExportTifFile);
                        ArcGIS.Core.Data.Raster.Raster tmpRaster = tmpFileRasterDataset.CreateDefaultRaster();
                        if (tmpRaster.CanEdit())
                            Envelope RasterExtent = EnvelopeBuilder.CreateEnvelope((double)rasterInfo.MinX, (double)rasterInfo.MinY, (double)rasterInfo.MaxX, (double)rasterInfo.MaxX, this._lastSelectedSR);
                            tmpRaster.SetExtent(RasterExtent);
                            tmpRaster.SetWidth(rasterInfo.RasterColumnCount);
                            tmpRaster.SetHeight(rasterInfo.RasterRowCount);
                            tmpRaster.Refresh();
                    }, ps.Progressor);
Tags (1)
Prashant_MukeshMangtani
Than,
In your code above when you create the extent envelope, you are setting MaxX instead of MaxY. Bolded below.
GKmieliauskas
Hi Than,
I think you need to save your raster to get updated properties. Look at this link:
https://community.esri.com/thread/213505-raster-setwidth-not-working
by Anonymous User
Not applicable
Thank Gintautas Kmieliauskas
That seems to be working now but it introduce another issue . The new set  of saved raster dataset create dam different cell size of Y value.
Yep it save extent, width, height but it changes the cell size.
GKmieliauskas
Hi Than,
What type is your rasterInfo.CellSize variable? Try to set constant value first (5,10 or 50). And you don't need to convert MakeValueArray arguments to string. They are all object type. MakeValueArray checks argument types itself and converts how it needs.
After MakeValueArray you can check parameters variable with debugger watch and see what value for cell size was defined.
by Anonymous User
Not applicable
Hi Gintautas,
Look like I confuse you.
Below is the full code snippet I used, the Raster Cellsize is good, when I used with Geoprocessing, after I called saved as method to save new set of raster data, it changed the cell size.
I attached the raster file before saveas and after save as function call.
string ExportTifFile = SourceFileName + ".tif";
                    string ExportFullTifFile = SourceFileName + "FullData.tif";
                    string tempFolderPath = Path.Combine(this.XYZInputModel.DestinationPath, "temp");
                    Directory.CreateDirectory(tempFolderPath);
                    //string ExportTifFile = SourceFileName;
                         tempFolderPath, // Output path
                         this.XYZInputModel.PixelType, // pixel type
                         1, "", SourceFileName,
                         "128 128", "NONE", ""
                         ); // Bands count
                    gpResult.Wait();
                        foreach (IGPMessage message in ProcessingResult.Messages)
                    //FillRasterData , FileSystemDatastore required to run under MCT
                        FileSystemConnectionPath connectionPath = new FileSystemConnectionPath(new System.Uri(tempFolderPath), FileSystemDatastoreType.Raster);
                        //temporary dataset
                        FileSystemConnectionPath finalConnectionPath = new FileSystemConnectionPath(new System.Uri(this.XYZInputModel.DestinationPath), FileSystemDatastoreType.Raster);
                        FileSystemDatastore finalDataStore = new FileSystemDatastore(finalConnectionPath);
                        ArcGIS.Core.Data.Raster.Raster tmpRaster = tmpFileRasterDataset.CreateFullRaster();
                            RasterStorageDef rasterStorageDef = new RasterStorageDef();
                            //New dataset -this method has issue * cellsize Y become shoot into very big number
                            RasterDataset FinalRasterDataset = tmpRaster.SaveAs(ExportFullTifFile, finalDataStore, "TIFF", rasterStorageDef);
                            //Need to remove temp folder and that Save as function update the original raster file cell size generated by geoprocessing
                            datastore.Dispose();
                            datastore = null;
                            connectionPath = null;
                            ArcGIS.Core.Data.Raster.Raster finalRaster = FinalRasterDataset.CreateFullRaster();
                            bool status = rasterUtility.FillRasterData(finalRaster, this.XYZInputModel.SourcePath, this.XYZInputModel.Delimiter, rasterInfo, this.XYZInputModel.PixelType);
                    }, ps.Progressor);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
GKmieliauskas
Hi Than,
Try to add line of code before calling SaveAs:
  rasterStorageDef.SetCellSize(rasterInfo.CellSize, rasterInfo.CellSize);
by Anonymous User
Not applicable
Thank Gintautas,
But no hope, still changing the cell size y.
Than,
by Anonymous User
Not applicable
Thank Prashant Mukesh Mangtani‌,
That right, I did typo error.
It solve the cell size issue .
Best Regards,
Than
