Renaming connected folders in ArcGIS Pro catalog view/pane
1005
12-05-2019 01:54 PM
JoeBorgione
ArcGIS Pro 2.4
Like so many others, my job is to create and test data and processes, first in our test environment(s) and finally in our production environment(s).  And I suspect like so many others the difference between our test and production environments is some variation in the path name.  For example, I create locators in :
\\someServer-t\arcgisresources\common\geocode    ( a test env and then copy them to):
\\someOtherServer\arcgisresources\common\geocode  (which is a production env)
If I add both of these folders to ArcGIS Pro, in a catalog view or pane, they both show up simply as geocode:
Is there a trick to renaming these so I can actually tell which is which?  I tried adding the actual paths but ArcGIS Pro won't accept special characters; I tried just adding a T or P as a prefix or suffix, and that doesn't stick.  Is this a designed limitation? If so, maybe the rename option should go away?  (Maybe this is ideas material?)
As an example, it's possible in ArcCatalog:
Kory Kramer
KoryKramer
Esri Community Moderator
This is where this is being tracked: https://community.esri.com/ideas/15625 Vote it up if you haven't yet!
KoryKramer
JoeBorgione
Awesome Kory!  Should have checked first!  I'm all in!
