I have a column of data in an attribute table that I would like to visually display on the map I am creating. How do I do this?
611
12-05-2019 04:05 PM
AddisonGaines
This column is directly linked to another column and I need to show this data on the map I am making. What do I have to do to display this data on the map?
FC_Basson
MVP Regular Contributor
You'll only be able to display it if you can link the attributes to a geometry or geometry fields (lat & lon and display as XY-event layer), or do a join to another feature class based on a unique attribute.
HeatherSmith
Hi Addison,
If the column is in a layer that has geometry, that layer will already be drawing on your map and you need to change the symbology/style so it references the column you want.
If the column is in a different layer - perhaps a table without any geometry, like a CSV file - then you need to join that table to your spatial layer using a common column before you can symbolize.
The specific instructions will vary depending on what product you are using. Here's documentation on changing symbology for three products:
ArcGIS Online: Change style—ArcGIS Online Help | Documentation
ArcGIS Pro: Symbolize feature layers—ArcGIS Pro | Documentation
ArcMap: About displaying layers—Help | ArcGIS Desktop
Additionally, you can learn how to do this in any of the Get Started lessons.
And here's documentation about joins:
ArcGIS Online: Join Features—ArcGIS Online Help | Documentation
ArcGIS Pro: Overview of joins and relates—ArcGIS Pro | ArcGIS Desktop
ArcMap: Joining attributes in one table to another—Help | ArcGIS Desktop
Table joins are also covered in the lesson Homeless in the Badlands.
