Sharing a Collector Map with Portal
679
12-05-2019 12:43 PM
ToddFagin
Occasional Contributor II
I have a created a simple map with a feature service for use in Collector. Both the feature service and the map are shared with "ArcGIS Enterprise." All of the parameters are set properly to work with Collector, as well. If I log in to Collector, I can access my map and collect features. However, if anyone else logs into our Portal via Collector, they cannot access the map. Obviously, the map is configured properly for Collector since I can use it. How can I ensure that other users can access it as well? (I have tried searching for this answer and only come up with things that do not solve the issue.)
Thank you,
Todd
Tags (3)
Kylie
by Esri Regular Contributor
Hi Todd! You'll need to share your map with a group, and have the mobile workers that need to access it be part of that group. You can learn more in "Share your map for use in Collector" here: Deploy your map—Collector for ArcGIS | Documentation
Esri Education Team
Kylie
Esri Education Team
ToddFagin
UGH. It is always the ridiculously simple solutions that I overlook. I was trying to figure out if there was something wrong with my map, with my feature service, the way it was published, etc., and all I had to do was create a group. Welp, as you know, that's correct. All is working now.
Thank you.
