GeoEvent Version Question
592
11-29-2019 05:57 AM
AndySkelton
New Contributor III
My license for GeoEvent 10.6.1 has evidently expired, but I have a license for 10.7.1, so I'm not SOL... Currently, all of my map services for GeoEvent are published to Portal 10.6.1. Am I going to cause issues if I upgrade GeoEvent to 10.7.1, but leave Portal on 10.6.1? The two servers are not federated.
Stefan_Jung
Hi Andy Skelton‌,
you can upgrade your GeoEvent 10.7.1 and leave your ArcGIS Enterprise on 10.6.1 to use the existing services. You already mentioned the most important part: This only works if they are not federated.
Under Data Stores of your GeoEvent you can register a connection to your ArcGIS Enterprise or ArcGIS Server to access your services.
I am not sure if you will be able to publish new services from GeoEvent 10.7.1 to your 10.6.1 AGE. I would expect that this is going to work but I cannot guarantee it. In general the GeoEvent would publish a hosted feature service, not sure if they there have been some canges from 10.6.1 to 10.7.1.
Best,
Stefan
AndySkelton
New Contributor III
Stefan,
Excellent! I had read in the documentation that if they *were* federated, I'd need to upgrade everything, but I wasn't quite sure what would happen if they weren't federated. Thanks for the clarification!
