requestOperation.data crash investigation
602
11-27-2019 06:10 AM
SerhiiKyrylenko
New Contributor III
From time to time I'm encountering crash during launching the application.
Runtime SDK version 100.6
Thread 8: EXC_BAD_ACCESS (code=1, address=0x0)
Thread 8 Queue : com.esri.arcgis.requestOperation.data (serial)
#0 0x000000010a72e08e in void std::__1::__tree_balance_after_insert<std::__1::__tree_node_base<void*>*>(std::__1::__tree_node_base<void*>*, std::__1::__tree_node_base<void*>*) ()
I've tried to execute
po (SEL)$arg2
but the result is <no value available>
(SEL)$arg3 -> " \xffffffd2\xffffff91"
(SEL)$arg5 -> "\x01/attriba"
Can someone take a look for the Runtime SDK source code in order to examine which methods are using the "com.esri.arcgis.requestOperation.data" serial queue? It might help to understand where the problem is.
Tags (3)
Nicholas-Furness
Anything that makes a network request will use requestOperation. Can you provide more of the stack trace?
SerhiiKyrylenko
New Contributor III
Sure, here is back trace for the thread where crash is happening:
* thread #17, queue = 'com.esri.arcgis.requestOperation.data', stop reason = EXC_BAD_ACCESS (code=1, address=0x0)
  * frame #0: 0x0000000102dfe08e ArcGIS`void std::__1::__tree_balance_after_insert<std::__1::__tree_node_base<void*>*>(std::__1::__tree_node_base<void*>*, std::__1::__tree_node_base<void*>*) + 190
    frame #1: 0x0000000103e5924d ArcGIS`Esri_runtimecore::Geo_model::ArcGIS_map_service_attribution_info::attribution_URL_for_service_URL(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) + 7949
    frame #2: 0x000000010392bf7d ArcGIS`Esri_runtimecore::Geo_model::ArcGIS_tiled_source::set_URI(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >) + 637
    frame #3: 0x000000010392bc65 ArcGIS`Esri_runtimecore::Geo_model::ArcGIS_tiled_source::create_from_URI(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >) + 85
    frame #4: 0x0000000103cf3897 ArcGIS`Esri_runtimecore::Geo_model::create_raster_tiled_datasource(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, Esri_runtimecore::Geo_model::Deserialization_context&) + 327
    frame #5: 0x0000000103cf8393 ArcGIS`Esri_runtimecore::Geo_model::deserialize(Esri_runtimecore::ArcGIS_rest::Basemap_layer const&, Esri_runtimecore::Geo_model::Deserialization_context&) + 3091
    frame #6: 0x0000000103c4b772 ArcGIS`Esri_runtimecore::Geo_model::deserialize_basemap(Esri_runtimecore::Geo_model::Basemap&, Esri_runtimecore::ArcGIS_rest::Basemap&, Esri_runtimecore::Geo_model::Deserialization_context&) + 706
    frame #7: 0x0000000103db2f80 ArcGIS`Esri_runtimecore::Geo_model::deserialize(Esri_runtimecore::Geo_model::Map&, Esri_runtimecore::ArcGIS_rest::Webmap const&, Esri_runtimecore::Geo_model::Deserialization_context&) + 960
    frame #8: 0x00000001039caf88 ArcGIS`Esri_runtimecore::Geo_model::Map::load_from_data_(unsigned char const*, unsigned long, std::exception_ptr const&) + 808
    frame #9: 0x00000001039d0776 ArcGIS`std::__1::__function::__func<Esri_runtimecore::Geo_model::Map::fetch_data_()::$_10, std::__1::allocator<Esri_runtimecore::Geo_model::Map::fetch_data_()::$_10>, void (std::__1::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > >, std::exception_ptr)>::operator()(std::__1::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > >&&, std::exception_ptr&&) + 86
    frame #10: 0x0000000103e0400d ArcGIS`Esri_runtimecore::Common::Slot<void (unsigned char const*, unsigned long, std::__1::shared_ptr<Esri_runtimecore::Common::Client_reference>)>::target_model<Esri_runtimecore::Geo_model::Portal_item::get_data_(std::__1::function<void (std::__1::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > >, std::exception_ptr)>, pplx::cancellation_token const&, bool)::$_6>::invoke(void const*, unsigned char const*, unsigned long, std::__1::reference_wrapper<std::__1::shared_ptr<Esri_runtimecore::Common::Client_reference> >) + 877
    frame #11: 0x0000000105b9a4eb ArcGIS`Esri_runtimecore::Common::Signal_detail::Signal_base::notify_(Esri_runtimecore::Common::Function_ref<void (Esri_runtimecore::Common::Signal_detail::erased_target_base&)>) const + 603
    frame #12: 0x0000000103df7239 ArcGIS`Esri_runtimecore::Geo_model::Portal_item::handle_response_(std::__1::shared_ptr<Esri_runtimecore::Common::Request> const&, unsigned char const*, unsigned long, std::__1::shared_ptr<Esri_runtimecore::Common::Client_reference> const&) + 1833
    frame #13: 0x0000000105b90e92 ArcGIS`Esri_runtimecore::Common::Request_delegator::handle_response(unsigned long long, unsigned char const*, unsigned long, std::__1::shared_ptr<Esri_runtimecore::Common::Client_reference> const&) + 130
    frame #14: 0x0000000105b8d4f0 ArcGIS`Esri_runtimecore::Common::Request::handle_response(unsigned char const*, unsigned long, std::__1::shared_ptr<Esri_runtimecore::Common::Client_reference> const&) + 112
    frame #15: 0x0000000103151f68 ArcGIS`RT_Request_handleResponse + 168
    frame #16: 0x0000000102b48479 ArcGIS`-[RTCRequest handleResponse:userDefinedError:error:] + 231
    frame #17: 0x0000000102d1bac2 ArcGIS`__71+[AGSRTCRequestDispatcher ags_kickOffCoreRequest:forRequestDispatcher:]_block_invoke.202 + 1420
    frame #18: 0x0000000102d45bae ArcGIS`__38-[AGSObservableOperation didComplete:]_block_invoke + 325
    frame #19: 0x0000000102b9f02e ArcGIS`ags_runWithMainThread + 66
    frame #20: 0x0000000102d45a47 ArcGIS`-[AGSObservableOperation didComplete:] + 264
    frame #21: 0x0000000102c65918 ArcGIS`-[AGSRequestOperation didComplete:] + 370
    frame #22: 0x0000000102d45896 ArcGIS`-[AGSObservableOperation finishWithResult:error:] + 132
    frame #23: 0x0000000102c6a367 ArcGIS`-[AGSRequestOperation finishWithResult:error:] + 773
    frame #24: 0x0000000102c67f2e ArcGIS`-[AGSRequestOperation requestOperationDidFinishLoading] + 595
    frame #25: 0x0000000102c67677 ArcGIS`-[AGSRequestOperation handleRequestCompletionWithError:] + 315
    frame #26: 0x000000010a5bfdd4 libdispatch.dylib`_dispatch_call_block_and_release + 12
    frame #27: 0x000000010a5c0d48 libdispatch.dylib`_dispatch_client_callout + 8
    frame #28: 0x000000010a5c75ef libdispatch.dylib`_dispatch_lane_serial_drain + 788
    frame #29: 0x000000010a5c817f libdispatch.dylib`_dispatch_lane_invoke + 422
    frame #30: 0x000000010a5d3a4e libdispatch.dylib`_dispatch_workloop_worker_thread + 719
    frame #31: 0x00007fff51c0171b libsystem_pthread.dylib`_pthread_wqthread + 290
    frame #32: 0x00007fff51c0157b libsystem_pthread.dylib`start_wqthread + 15
My guesses: may be it's because of creating two or more map objects... previously I've encountered 100% crash while trying to display two map views on the same screen. Current application displays only one map view, but creates and loads few map objects. Isn't that an anti-pattern for the Runtime SDK and AGSMap instance should be globally visible singleton object instead?
P.S. Following my guess. Looks like trick with the singleton map object did the job for me. Crash is absent so far.
