Hello GIS friends,
Is there an arcade expression I can use to calculate xy values for a point feature? I am using this (return Round(Geometry($feature)x, 6) expression, but it is not doing the work. My field name is Point_X and Point_Y.
Thank you very much,
Abi
Hi Abi Dhakal ,
You are missing a dot "." in the expression, It should be:
... but if it is working for you, then I assume it is just a typo.
You are mentioning WKID 3857 (Web Mercator Auxiliary Sphere) and that you want it in meters. However, this is a spatial reference that already return the coordinate in meters. If you want to obtain decimal degrees (WGS 1984) you can use a conversion to get that. See example here: https://community.esri.com/message/806053-re-latlong-unit-conversion-with-arcade?commentID=806053#comment-806053
