I have a layer for our cameras. They can be accessed via IP address in a browser. If I copy/paste IP address in browser it works. In ArcMap I used hyperlinks (URL option) and it worked with the hyperlink tool. But in ArcGIS Pro it's not working. I selected Text, selected the field, highlighted it, clicked on hyperlink pulldown, set the field ({IPAddress}) as URL, put description in (open camera...). But when I click on a point, I can see the hyperlink description, nothing happens when I click on it.
UPDATE/SOLVED: I figured it out while typing this question, so I'm posting with my solution: I created an expression in POPUP, then when I select from list of fields for hyperlink, it shows expression and I use that rather than field with IP address. Expression used Concatenate("http://", {IPAddress})
