Not able to access Survey123
313
11-17-2019 05:39 AM
Sunnyh
I have recently purchased ArcGis for Personal use and my licence is valid.  But I am unable to login to Survey123 .
Below is the error http://survey123.arcgis.com/share/common/error?errorCode=webform04
You need an ArcGIS Online subscription account to try Survey123 for ArcGIS.
Kindly help me how to activate survey123.
by Anonymous User
Not applicable
Hi Sunny!
Are you using named-user licensing with Survey123?  If so it looks like you may need to first log into arcgis.com to enable the Survey123 license.
Try this:
  • Log into arcgis.com
  • Select "licenses"
  • In the "Search add-on licenses" search bar type "Survey123
  • "Survey123 for ArcGIS" should appear as a result, select "Manage"
  • Search for the username that you would like to use Survey123 with
  • There should be a radio button on the right hand side.  Select that to authorize the license.
  • A prompt should appear asking you if you would like to email the member (in this case, yourself).  You can select yes.
  • You should now be able to use Survey123! : )
Let me know if this works for you.
