What´s the differences to publish from Desktop to Server and Portal
561
11-15-2019 09:00 AM
SoratoSouza_e_Silva
Occasional Contributor II
I created two connection in Arcmap. One to Server other to Portal. The Server is federated with Portal.
What is the difference between publishing directly to the server than publishing directly to the Portal (both using arcmap)?
Thank´s
Tags (1)
PanagiotisPapadopoulos
From ArcGIS Desktop when you are connected to Portal (Enterprise) you have the ability to share hosted services
Publish to ArcGIS Online and ArcGIS Enterprise—Publish services | ArcGIS Desktop
From ArcGIS Desktop when you are connected to ArcGIS Server (directly) you have the ability to share all the other types of services.
Publish a map service from ArcMap—Publish services | ArcGIS Desktop
SoratoSouza_e_Silva
Thank´s
