Survey123 crashes on iOS devices with same select one question
720
5
11-12-2019 10:16 AM
KatherinePadilla
I have a survey that keeps crashing the app on iOS devices when the Flow Observed question is answered a certain way.  (FLOW_OBSERVED).  I have similarly structured surveys that do not have this problem.
iOS version 13.2.2
Survey123 version 3.6.158
Functions Fine:
Windows 10, Survey123 64 bit version 3.6.153
SM-G900V, Android version 6.0.1, Survey123 version 3.6.157
I have tried to do a whole new publish - same issue.
I have tried to remove the / as recommended in a comment below, with a whole new publish - same issue.
Katie.
DougBrowning
MVP Esteemed Contributor
Try removing the special chars like
Chollas Creek LG/LM Boundary
and
Mission Bay/La Jolla
and
MB/LJ
Messed me up a few times
KatherinePadilla
Interesting. This is definitely not the first time I have published this survey, yet the first time I have had this issue. I will give it a try though.
Thanks.
KatherinePadilla
Thanks for the suggestion Doug, this did not work for my survey.
JamesTedrick
Esri Esteemed Contributor
Hi Katherine,
I can see the crash on the form sample you've provided. It appears that this is specific to the design of your form - could I ask that you file a BUG with Esri Support so that we can better diagnose what is occurring?
JayH
New Contributor III
I had the same issue, but could fix by republishing it. What I did was creating new survey, and copied the content in the form into new form. I am still not sure what was the issue- everything else was the same.
