I'm trying to utilize the charts in Pro.
I'm having an issue when trying to size it.The chart always keeps this extra space at the bottom. When I try to resize the chart, it just scales with the big empty space at the bottom.
Hi Adam,
I'm assuming that you are resizing a Chart Frame (Chart frames—Layouts | ArcGIS Desktop) on a Layout. I have not run across a chart/scenario where there is as much extra empty space as in your screenshot. The Chart Frame is designed to replicate as best as possible what is shown in the Chart window or view (Make a chart—Charts | ArcGIS Desktop). When you customize the look of the chart (Change chart appearance—Charts | ArcGIS Desktop) both the Chart window/view and the Chart Frame in the layout should display these changes.
Does the Chart window/view also show the extra, empty spaces?
Tom
