Parcel Fabric "Gotcha"
777
11-08-2019 11:22 AM
Syvertson
Occasional Contributor III
I just found, what I believe to be, a glitch in the fabric.  I am wondering if anyone else has experienced similar problems.
Here is the glitch:
After joining a table, I get strange errors when editing.  Using the clip function, I get an error that the line must pass through the feature in two places, when it was passing through it correctly.  Remove the join and try the same edit, and it works just fine.  When rotating or moving a parcel, everything looks fine, until I click finish and it would then the parcel moves right back, but I get an indication that it was successful in the edit pane.
This is demonstrated in the video (below):
AmirBar-Maor
@Syvertson
Did you submit this with technical support?
Which version of ArcGIS Pro are you using?
Please submit any suspected bugs with technical support
Syvertson
I opened a tech support case, and they troubleshot with me and then classified it as a bug (https://my.esri.com/#/support/bugs/BUG-000140067 )  The case has since been fixed and case closed.
