Sewer Network Viewer demo appears to be broken
364
11-07-2019 10:57 AM
Mark_Johnson
New Contributor III
When I try the Sewer Network Viewer v2.0 app at https://www.arcgis.com/home/item.html?id=d5bfffa6dc934f71bedbce8f2cbfd26a all I see on the map is a large purple rectangle, no sewer features appear when I zoom in. Can someone confirm? Is this the best/correct demo app to be looking at?
ElenaFernandes
Hello Mark,
It looks like you are viewing our deployment item directly in our organization. This item is used to deploy the Sewer Network Viewer v2.0 into your Portal using the ArcGIS Solutions Deployment Add-IN for ArcGIS Pro. You can find the steps to Install the ArcGIS Solutions Deployment Add-In—Get Started | ArcGIS for Water here. The item you are viewing is not intended to be used for demo purposes and you will need to deploy our solution to your Portal in order to view the app and play around with it.
Elena
