I have made an app which uses the Info Summary Widget to summarise the features displayed on the current extent of the map.
The features are species sightings which are coming from multiple layers (flora, fauna, angiosperms, all sightings and so on).
The Info Summary Widget worked very well for me when the MXD that I had published a few months ago only had one or two layers (all sightings). At that point I used the Info Summary Widget to summarise those feature by 'Family'.
Now that I have more layers which separates fauna from flora and other classes and groups, I use this widget so summarise tow layers; fauna and flora grouped by 'flora group' and 'class'. This was working very well until I made a few edits to the map (renamed a layer, enabled pop up window, added labels to another layer) Since then, Every time that I use the Info Summary Widget, for some weird reason all the layers get turned on by themselves, even those turned off in the layer tool.
Now I have spent hours trying to understand where the problem was coming from. And started narrowing down where the problem started. So I have removed my web service from the map and re added the same layer from web and reset the Info Summary widget to point to flora and flora. Worked great.
Then, I have started to re edit the map and re enable pop-up window. Worked great when I used the Info summary tool.
Then I went back to the map and added labels to a layer. And for some weird reason, when I used the Info Summary tool in the app, all the layers turn on by themselves again.
I have removed and re added and my layers dozen of times, tried every edit and solution I could think of. Everything works I add labels to any layer in the map and that create a bug where all the layers will turn on when I use the Info Summary Widget.
If you know how I could fix this that would be very helpful!
Jeremy
Here is a few photos of what I am doing (basically three steps: 1 setting up he Info Summary Widget and making sure is works, which is does. 2. Making edits to the map by adding label. 3. re-checking how the app works and seeing that the Info Summary Widget now makes all layers appear for no reason.
The URL I have been using and which worked great until now:
http://sirgisdev/arcgis/rest/services/WildNet2/MapServer
https://uat-gisservices.information.qld.gov.au/arcgis/rest/services/EncompassApps/WildNet/MapServer
Jeremy Wolff
Biodiversity Information Officer (WildNet Program) - Spatial and Wildlife Unit
Science Information Services – Digital and Information Services - Science & Technology Division
Department of Environment and Science
__________________________________________________________________
P 07 3170 5425 E Jeremy.Wolff@des.qld.gov.au
Ecosciences Precinct G.C.W. 41 Boggo Road Dutton Park QLD 4102 or GPO Box 2454 Brisbane QLD 4001
Customers first | Ideas into action | Unleash potential | Be courageous | Empower people
