Is there a command in the Task Designer to active the Versioning Ribbon?
249
11-04-2019 01:34 PM
ShelleySchulte1
New Contributor III
I am trying to create a task for versioning and a few other steps.  I know manually you have to view Data by Source and then select the source of the data you want to version, then the versioning ribbon appears.  Is there anyway to make the version appear in the task design editor to run as a task step?  I've been looking but can't find a way to achieve this expecting manually doing it in the TOC.
Thanks!
Shelley
Tags (3)
