Failed to Create ArcGIS Enterprise Portal Site
2726
5
10-24-2019 03:43 AM
Suleyman-Arslan
I am not able to install ArcGIS Enterprise Portal.
When I try to create portal site, I receive error; "Index Service configuration failed."
OS: Windows 10 Enterprise Version 1903
ArcGIS Enterprise Version: 10.7.1
Please advise me to resolve problem.
Logfile as below;
<Msg time="2019-10-24T12:36:46,418" type="INFO" code="217039" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Log Service started.</Msg>
<Msg time="2019-10-24T12:36:49,314" type="INFO" code="217036" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Create SAML certificate output .</Msg>
<Msg time="2019-10-24T12:36:49,329" type="INFO" code="217031" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Configuring and initializing data, content and index directories.</Msg>
<Msg time="2019-10-24T12:36:49,376" type="INFO" code="209092" source="Portal Admin" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Unzipping the portal content.</Msg>
<Msg time="2019-10-24T12:36:50,267" type="INFO" code="217032" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Replacing base URLs in configuration files.</Msg>
<Msg time="2019-10-24T12:36:50,267" type="INFO" code="217009" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">httpUrl: xxxxxxx.LOCAL:7080.</Msg>
<Msg time="2019-10-24T12:36:50,267" type="INFO" code="217010" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">httpsUrl: xxxxxxx.LOCAL:7443.</Msg>
<Msg time="2019-10-24T12:36:50,267" type="INFO" code="217011" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">baseUrl: xxxxxxx.LOCAL:7080/arcgis.</Msg>
<Msg time="2019-10-24T12:36:50,267" type="INFO" code="217012" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">sbaseUrl: xxxxxxx.LOCAL:7443/arcgis.</Msg>
<Msg time="2019-10-24T12:36:58,575" type="INFO" code="217033" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Configuring web server ports.</Msg>
<Msg time="2019-10-24T12:36:58,606" type="INFO" code="217015" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Found identity store type .</Msg>
<Msg time="2019-10-24T12:36:58,606" type="INFO" code="217034" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Configuring Proxy Properties</Msg>
<Msg time="2019-10-24T12:36:58,638" type="INFO" code="217035" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Configuring the index service credentials.</Msg>
<Msg time="2019-10-24T12:36:58,638" type="INFO" code="217002" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Portal configuration updated.</Msg>
<Msg time="2019-10-24T12:36:58,638" type="INFO" code="217046" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting process monitor.</Msg>
<Msg time="2019-10-24T12:36:58,638" type="VERBOSE" code="217063" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">The process monitor did not find the connection to the configuration store. The site may not have been initialized. After the site is initialized, the check for database processes will be reattempted.</Msg>
<Msg time="2019-10-24T12:36:58,653" type="INFO" code="217055" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting watchdog thread run.</Msg>
<Msg time="2019-10-24T12:36:58,653" type="VERBOSE" code="217063" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">The process monitor did not find the connection to the configuration store. The site may not have been initialized. After the site is initialized, the check for database processes will be reattempted.</Msg>
<Msg time="2019-10-24T12:36:58,653" type="INFO" code="217074" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Portal started successfully.</Msg>
<Msg time="2019-10-24T12:36:58,653" type="INFO" code="217044" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Log limiter: Started removing logs older than 90 days in path D:\arcgisportal\logs\xxxxxxx.LOCAL\portal.</Msg>
<Msg time="2019-10-24T12:36:58,653" type="INFO" code="217045" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Log limiter: Finished removing logs older than 90 days in path D:\arcgisportal\logs\xxxxxxx.LOCAL\portal.</Msg>
<Msg time="2019-10-24T12:37:02,747" type="WARNING" code="217064" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">The web server was found to be stopped. Re-starting it.</Msg>
<Msg time="2019-10-24T12:37:02,747" type="INFO" code="217053" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting the web server.</Msg>
<Msg time="2019-10-24T12:37:36,143" type="INFO" code="217054" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Started web server.</Msg>
<Msg time="2019-10-24T12:41:45,546" type="INFO" code="207037" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Log level updated to 'VERBOSE'.</Msg>
<Msg time="2019-10-24T12:41:45,635" type="INFO" code="205013" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Log settings updated. [Logs directory = 'D:\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2019-10-24T12:41:45,636" type="VERBOSE" code="209001" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Setting log level to VERBOSE before creating new site.</Msg>
<Msg time="2019-10-24T12:41:45,636" type="INFO" code="209002" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Creating new site.</Msg>
<Msg time="2019-10-24T12:41:45,883" type="INFO" code="209003" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">This is a fresh install.</Msg>
<Msg time="2019-10-24T12:41:45,883" type="INFO" code="209089" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Portal for ArcGIS version is 10.7.1.</Msg>
<Msg time="2019-10-24T12:41:45,883" type="INFO" code="209090" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting to initialize the content module.</Msg>
<Msg time="2019-10-24T12:48:57,17" type="INFO" code="209091" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Content module initialization complete.</Msg>
<Msg time="2019-10-24T12:48:57,17" type="INFO" code="209004" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting to initialize DB module.</Msg>
<Msg time="2019-10-24T12:48:57,30" type="INFO" code="209067" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Initializing the database.</Msg>
<Msg time="2019-10-24T12:49:18,969" type="INFO" code="209068" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting the database server.</Msg>
<Msg time="2019-10-24T12:49:25,163" type="INFO" code="209069" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Creating the database.</Msg>
<Msg time="2019-10-24T12:49:34,180" type="INFO" code="209070" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Creating the database admin account.</Msg>
<Msg time="2019-10-24T12:49:44,984" type="INFO" code="209071" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Loading template data into the database.</Msg>
<Msg time="2019-10-24T12:49:53,718" type="INFO" code="209064" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Stopping the database.</Msg>
<Msg time="2019-10-24T12:50:03,770" type="INFO" code="209072" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Blocking database access to everybody but the localhost.</Msg>
<Msg time="2019-10-24T12:50:03,828" type="INFO" code="209068" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting the database server.</Msg>
<Msg time="2019-10-24T12:50:10,267" type="INFO" code="209005" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">DB module initialized.</Msg>
<Msg time="2019-10-24T12:50:10,267" type="INFO" code="209006" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting to initialize configuration store module.</Msg>
<Msg time="2019-10-24T12:50:10,279" type="INFO" code="209007" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Configuration store module initialized.</Msg>
<Msg time="2019-10-24T12:50:10,279" type="INFO" code="209008" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting to initialize security module.</Msg>
<Msg time="2019-10-24T12:50:10,802" type="INFO" code="205003" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Token configuration updated.</Msg>
<Msg time="2019-10-24T12:50:10,818" type="INFO" code="205005" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Testing connection to user store.</Msg>
<Msg time="2019-10-24T12:50:10,826" type="INFO" code="205009" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Identity store updated.</Msg>
<Msg time="2019-10-24T12:50:10,830" type="INFO" code="205006" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Testing connection to role store.</Msg>
<Msg time="2019-10-24T12:50:10,836" type="INFO" code="205009" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Identity store updated.</Msg>
<Msg time="2019-10-24T12:50:10,847" type="INFO" code="209009" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Security module initialized.</Msg>
<Msg time="2019-10-24T12:50:10,847" type="INFO" code="209010" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting to initialize server directories module.</Msg>
<Msg time="2019-10-24T12:50:10,885" type="INFO" code="207019" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">'content' directory registered with the portal.</Msg>
<Msg time="2019-10-24T12:50:10,910" type="INFO" code="207019" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">'index' directory registered with the portal.</Msg>
<Msg time="2019-10-24T12:50:10,931" type="INFO" code="207019" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">'db' directory registered with the portal.</Msg>
<Msg time="2019-10-24T12:50:10,965" type="INFO" code="207019" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">'temp' directory registered with the portal.</Msg>
<Msg time="2019-10-24T12:50:10,965" type="INFO" code="209011" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Server directories module initialized.</Msg>
<Msg time="2019-10-24T12:50:10,965" type="INFO" code="209012" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting to initialize logging module.</Msg>
<Msg time="2019-10-24T12:50:10,970" type="INFO" code="207037" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Log level updated to 'VERBOSE'.</Msg>
<Msg time="2019-10-24T12:50:10,990" type="INFO" code="205013" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Log settings updated. [Logs directory = 'D:\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2019-10-24T12:50:10,990" type="INFO" code="209013" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Logging module initialized.</Msg>
<Msg time="2019-10-24T12:50:10,990" type="INFO" code="209014" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Initializing ArcGIS Web Adaptor configuration.</Msg>
<Msg time="2019-10-24T12:50:10,998" type="INFO" code="209015" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">ArcGIS Web Adaptor configuration module initialized.</Msg>
<Msg time="2019-10-24T12:50:10,998" type="INFO" code="209016" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting to initialize system configuration module.</Msg>
<Msg time="2019-10-24T12:50:11,0" type="INFO" code="209017" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">System Configuration module initialized.</Msg>
<Msg time="2019-10-24T12:50:11,0" type="INFO" code="209018" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting to initialize administrator account module.</Msg>
<Msg time="2019-10-24T12:50:11,715" type="INFO" code="209019" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Administrator account module initialized.</Msg>
<Msg time="2019-10-24T12:50:36,270" type="WARNING" code="218014" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting Index Service.</Msg>
<Msg time="2019-10-24T12:50:36,302" type="WARNING" code="218015" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Started Index Service.</Msg>
<Msg time="2019-10-24T12:50:50,843" type="INFO" code="211000" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Re-creating the indexes for mode: 'FILE_MODE'</Msg>
<Msg time="2019-10-24T12:51:08,80" type="INFO" code="211000" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Re-creating the indexes for mode: 'FILE_MODE'</Msg>
<Msg time="2019-10-24T12:51:25,480" type="INFO" code="209020" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting to initialize indexer module.</Msg>
<Msg time="2019-10-24T12:51:25,486" type="INFO" code="218022" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Elastic node configuration started.</Msg>
<Msg time="2019-10-24T12:51:52,791" type="WARNING" code="218014" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting Index Service.</Msg>
<Msg time="2019-10-24T12:51:52,793" type="WARNING" code="218015" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Started Index Service.</Msg>
<Msg time="2019-10-24T12:53:08,532" type="WARNING" code="218014" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Starting Index Service.</Msg>
<Msg time="2019-10-24T12:53:08,535" type="WARNING" code="218015" source="Portal" process="14680" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Started Index Service.</Msg>
<Msg time="2019-10-24T12:53:51,579" type="SEVERE" code="110506" source="Data Store" process="13880" thread="65" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Attempt to configure data store failed. Attempt to configure data store failed.. Extended error message: Failed to configure spatiotemporal big data store.. Extended error message: Failed to start spatiotemporal big data store machine.. Extended error message: Failed to start spatiotemporal big data store machine.</Msg>
<Msg time="2019-10-24T12:53:51,579" type="SEVERE" code="218028" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Index Service configuration failed.</Msg>
<Msg time="2019-10-24T12:53:51,579" type="SEVERE" code="209024" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">The process of creating a new site failed. Reverting site creation. Index Service configuration failed.</Msg>
<Msg time="2019-10-24T12:54:06,776" type="INFO" code="209074" source="Portal Admin" process="13880" thread="1" methodName="" machine="xxxxxxx.LOCAL" user="" elapsed="" requestID="">Connection file deleted from disk.</Msg>
JakeSkinner
Esri Esteemed Contributor
Hi Suleyman,
How many cores does this machine have?  I've seen this issue occur when there is only a single core.  At 10.7, a minimum of 2 cores are required.
Suleyman-Arslan
I am installing on my laptop with single CPU, 8 core.
Actually 10.6 was running on this laptop. This happend when I try to upgrade 10.7.1.
After failed upgrade, I uninstalled all esri products and reinstall give me same error.
johnnido
Hi Jake, I am also encountering a similar error.
"There was an error creating your initial administrator account.
Migration failed. null"
The log says:
I am currently deploying 10.9
PaulHallett1305
Did you ever fix this Johnnindo?
ChristopherBertrand
I recently had and solved what seems like an identical problem.
At the beginning of our installation, I checked that the hardware on our brand new server was up to specifications and never checked again for a month.  After a month of troubleshooting, someone suggested that we check the number of cores.  I had our IT department create/assign 8 virtual cores on our server.  Portal installed and configured with no problem after that.
