The option in the above screenshot is available in the ArcMap right click context when drawing a rectangle. I can't seem to find the same option in ArcGIS Pro, and my searches online have been fruitless. Can anyone point me to this feature in Pro?
Thanks!
Hi Sean,
Until Pro has the horizontal option (hopefully in the near term), you can constrain the rectangle to a specific direction. If your map has no rotation, it can work like this:
In this case, I use "90-1". The "90" specifies 90 degrees and the "-1" part set the quadrant as northeast. That's because my project direction units are set to Quadrant Bearing:
This can be adapted to any of the direction units.
I hope this helps in the meantime.
Scott
