ArcPro 2.3.2 Apply Raster Stretch Symbology using ArcPy
489
10-23-2019 08:44 AM
JohnMossing
Is it possible to access all the raster symbology properties using ArcPy in pro? I am trying to classify a raster layer using Stretch, Standard Deviation, with a custom Color Scheme. I have tried to search here a good deal and all i keep finding is references to this page: Stretch function—ArcGIS Pro | ArcGIS Desktop
However there is no arcpy code samples there. If it is possible to access these properties using arcpy can someone please point me to some code samples.
I might use ApplySymbologyFromLayer_management, however there is bug that is preventing this tool from applying the symbology when run from a script.
Ideally I would prefer a coding solution so i do not have to have a layer file. Thank you.#
Tags (1)
