AnsweredAssumed Answered
AGE Builder 10.7.1 - The Web Adaptor URL cannot be reached
Question asked by valraa on Oct 17, 2019
Latest reply on Oct 24, 2019 by valraa
Trying to install AGE 10.7.1 with Builder.
Before launching the setup, i changed my etc/hosts file to let my server see itself as sit.a4mobility.it rather than its FQDN (svksi058anew.globalnt.it)as suggested in https://community.esri.com/thread/208069-impossible-to-log-in-to-arcgis-server-federated-with-portal-after-installation-…
The etc/hosts now has this line
   MY_SERVER_IP sit.a4mobility.it
To confirm it works, pinging the server with ping -a  MY_SERVER_IP shows sit.a4mobility.it rather than the FQDN.
I launched the installation and everything went fine (all green check marks).
Then, opening the configuration wizard in the browser, (i changed the URL from http://localhost:6080/arcgis/enterprise to http://sit.a4mobility.it:6080/arcgis/enterprise ), after filling all the information, I reach the error:
The wizard is redirecting to the FQDN (https://svksi058anew.globalnt.it/server), and there's no way I can make it work.
I can however reach https://sit.a4mobility.it/server which redirects me to the Web Adaptor configuration page (https://sit.a4mobility.it/server/webadaptor ), meaning that probably the etc(hosts trick worked.
Unfortunately, I have no idea how I would make the Builder configuration wizard to point to this address rather than the FQDN one.
I am again stuck with installing AGE with Builder and I REALLY hope someone will shed a light on how I can solve this without removing everything and reinstalling each component manually (that is one day of work at least).
There's also this other thread https://community.esri.com/thread/210356-web-adapator-for-arcgis-server-is-not-taking-domain-name-arcgis-server#comment-… where Jonathan Quinn says:
1) Use the hosts file under C:\Windows\System32\drivers\etc to set the alias so the Builder will use that hostname for configuring everything:
Ex.
10.0.0.1 webgis.domain.com
This however seems to have failed in my case, and according to the many threads I found on Geonet, most people just gave up and did a manual install of the AGE components separately...
Outcomes
