Rotate and resize the feature by using ArcGIS runtime SDK for .Net
2093
10-17-2019 12:26 AM
DharmaRajan
Hi All,
I want to rotate and resize the feature by using "MapView.SketchEditor", with the options 'AllowRotate' and 'ResizeMode' in 'SketchEditConfiguration' are set as True. I can able to edit the vertices. But I cann't able to find any Anchor-Point which enables me to rotate or resize. Kindly suggest the way to achieve this.
DharmaRajan
Hi All,
The issue was resolved and the sample code snippet is given below.
//The below one is the code which was used initially and it was build successfully without any error. But no expected output.
SketchEditConfiguration sktEditConfig = MyMapView.SketchEditor.EditConfiguration;
sktEditConfig.AllowRotate = true;
Esri.ArcGISRuntime.Geometry.Geometry newGeometry = await MyMapView.SketchEditor.StartAsync(geom);
//This below given code is replaced with the above one and now it is working fine.
SketchEditConfiguration sktEditConfig = new SketchEditConfiguration();
Esri.ArcGISRuntime.Geometry.Geometry newGeometry = await MyMapView.SketchEditor.StartAsync(geom,SketchCreationMode.Polyline,sktEditConfig);
DharmaRajan
Hi All,
