How to select default web app layers upon launching
522
10-16-2019 12:50 PM
KyrstenFrench
Is there a way to set which layers are active when the web app launches? Currently, these layers are active when I launch, but I want Zoning and Reference Points to be the only active layers when this app is opened.
Tags (1)
RobertScheitlin__GISP
The normal way is to edit the webmap and set the layers you want visible there. You can also use the "App State" in the WAB Attributes tab to keep the apps layers visible state to the last saved state when you close the app.
KyrstenFrench
Thank you!
