Setting a Temperature Range
3529
13
10-16-2019 10:02 AM
BRYANHERRON
New Contributor III
I have a Survey question that is simply the temperature. Our field guys won't be working on days that are -200 degrees or 200 degrees, but I can't figure out how to force there answers to the question between a certain range. How do you do this?
JeremyJohnson5
New Contributor III
In the constraints field try the following: .>-20 and .<120
RobertBorchert
Frequent Contributor III
Set up a domain for the question that has a ranged value.  You can set the minimum and the maximum.
BRYANHERRON
New Contributor III
Easy for you to say. hehe
I am not familiar with setting up a domain.
JeremyJohnson5
New Contributor III
If you are using Survey123 Connect you could set up a Constraint that would limit the values to be entered.
BRYANHERRON
New Contributor III
I can't get the constraint's syntax correct for a range of -20 to 120.
RobertBorchert
-20 to 120 goodness I wish.  We have a range of -40 to 110.   But for safety concerns we don't send out crews when it is that cold.
BRYANHERRON
New Contributor III
The work our guys do usually can't be done when the ground is frozen, so -20 may be giving them a lot of leeway.
RobertBorchert
Well at least Gators are not a concern.
JeremyJohnson5
New Contributor III
BRYANHERRON
New Contributor III
Yep, I thought I had tried that as well.
I have Gremlins...
